Industry White Paper
Cutting−Edge Global Shutter Image Sensors for High−Speed Applications
Choosing a CMOS digital image sensor with an active-pixel array for a high-speed application is no simple task. This white paper examines critical image sensor considerations with a focus on detecting fast moving objects with image sensors. Understand the performance considerations of global shutter sensors, and learn of each of the application-driven metrics you should keep in mind.
October 08, 2024 by onsemi
Topics Covered
Rolling Shutters vs Global Shutters
Global Shutter Performance Considerations
onsemi’s Hyperlux SG Family of Global Shutter Sensors
Hyperlux SG Applications
White Paper Overview
When selecting a CMOS digital image sensor with an active-pixel array, there are a lot of sensor specifications to consider. Everything from resolution to optical format to shutter type and more need to be analyzed.
This paper sheds light on the critical considerations for image sensors, with a focus on detecting fast-moving objects. The speed of the object being imaged will dictate the appropriate shutter type,  rolling shutter or global shutter.
Download this white paper to learn the differences between rolling shutter and global shutter image sensors. It breaks down the performance considerations of global shutter sensors and examines each application-driven metric. The paper also discusses the details of onsemi's Hyperlux SG Family of global shutter sensors.
Read White Paper:
