Industry White Paper
DC Energy Metering Applications
Used in electric vehicle charging stations, sustainable microgrids, and high-efficiency data centers, precision DC energy metering is critical for accurate billing and reducing CO2 emissions, but traditional AC-side measurements and technical challenges like shunt self-heating and the Seebeck effect often limit performance. This white paper from Analog Devices details a design utilizing the ADA4528 zero-drift amplifier and AD7779 24-bit ADC to overcome measurement drifts and achieve 0.5% class accuracy across a wide dynamic range.
White Paper Overview
Used in electric vehicle (EV) charging stations, sustainable microgrids, and high-density data centers, DC energy metering is essential for reducing CO2 emissions and optimizing power conversion efficiency in the 21st century. This article examines the principles of direct current distribution—which can improve building energy efficiency by up to 28% compared to traditional AC systems—and the technical limitations of current sensing, such as self-heating and the Seebeck effect, that challenge the accuracy of modern billing-grade meters.
Read this white paper from Analog Devices to discover how a precision DC energy meter design improves measurement performance using a high-performance signal chain featuring the ADA4528 zero-drift amplifier and the AD7779 24-bit simultaneous sampling ADC. The solution utilizes a low-resistance 75 µΩ shunt to minimize power dissipation while employing a "4-wire" measurement configuration to accurately discount resistive losses in charging cables.
The paper also highlights how this advanced metering architecture supports diverse high-power applications, including ultrafast EV chargers (up to 500 kW), renewable energy microgrids, and data center Power Usage Effectiveness (PUE) monitoring. Features such as 0.5% class accuracy, 2.5 kHz bandwidth, and integrated system interfaces like RS-485 and LCD support make this design a versatile and scalable solution.
