Industry White Paper
Designing Modern Motor Control Systems with Geehy’s Scalable MDP Platform
Learn how Geehy's scalable Motor Drive Platform helps engineers match motor control silicon to each design while reusing code, tools, and supply chain across product lines.
White Paper Overview
Motor control designs range from battery-powered handheld tools and ceiling fans to high-voltage industrial pumps and multi-axis servo drives. Each application brings its own constraints in voltage, size, cost, algorithm complexity, and communication, and no single MCU serves the whole range well.
Geehy Semiconductor’s Motor Drive Platform (MDP) addresses this with a scalable ecosystem of motor control MCUs, integrated motor control SoCs, gate drivers, intelligent power modules (IPMs), and a shared software and algorithm platform.
In this white paper, you will learn:
• How integrated “2-in-1” and “3-in-1” motor control SoCs reduce board size and BOM cost
• How pairing the G32F031 MCU with the GHP500N05 intelligent power module supports flexible, customized designs
• How the G32R501/502 real-time control MCU/DSP handles advanced motor control algorithms
• How a unified portfolio enables code reuse, shared development tools, and a simpler supply chain
