Industry White Paper
DIN/Panel Mount Power Supplies for Data Centers
Rack densities are hitting 100kW+. See how a unified DIN rail and panel mount power strategy cuts PUE and TCO across your data center's White and Grey areas.
September 01, 2026 by Acal BFi
Topics Covered
DIN Rail & Panel Mount Power Strategies
White Area vs. Grey Area Power Requirements
Reducing Power Usage Effectiveness (PUE)
Lowering Total Cost of Ownership (TCO)
Improving Reliability, Diagnostics & Maintenance
Scaling Power Infrastructure for AI Data Centers
White Paper Overview
As AI workloads continue to drive unprecedented data center growth, supporting infrastructure is under increasing pressure to deliver greater efficiency, reliability, and scalability. While high-density computing attracts much of the attention, the auxiliary power supplies that support cooling systems, building management, sensors, controllers, and monitoring equipment play a critical role in maintaining uptime and improving overall energy efficiency.
This paper examines how the climate-controlled White Area and the more demanding Grey Area place fundamentally different requirements on DIN rail and panel mount power supplies — and how a unified architecture across both zones can reduce PUE, lower TCO, and simplify system design. It walks through the environmental and operational differences between the two zones, and demonstrates how consistent diagnostics, shared certifications, and standardized form factors improve maintenance, speed up infrastructure expansion, and give facility teams a coherent, facility-wide view of power health.
Whether you're designing next-generation AI data centers, upgrading cooling infrastructure, or integrating building management systems, you'll find practical insight into choosing power solutions that maximize performance, resilience, and long-term operational efficiency.
Download the white paper to see how a unified DIN rail and panel mount power strategy can help you optimize power distribution, improve reliability, and support the evolving demands of modern AI data centers.
Read White Paper:
