Industry White Paper
DisplayPort: Compliance and Signal Integrity Debugging
As DisplayPort data rates and bandwidth requirements continue to increase, comprehensive PHY compliance testing is essential to verify signal integrity and interoperability. This application note outlines the key measurement methodologies for validating DisplayPort source transmitters and passive cables, including oscilloscope-based compliance testing, signal integrity analysis, and VNA-based S-parameter characterization.
August 03, 2026 by Rohde & Schwarz
Topics Covered
DisplayPort Compliance Testing
Transmitter Test Points & Measurements
Automated Testing with ScopeSuite
Jitter Decomposition & Debug
Application Note Overview
As DisplayPort continues to support higher resolutions, faster data rates, and increased bandwidth, comprehensive compliance testing is critical to ensure interoperability and signal integrity across devices and interconnects. This application note provides an overview of physical layer compliance testing for DisplayPort source transmitters and passive cables in accordance with VESA CTS v2.1. It explains oscilloscope-based transmitter measurements, automated test execution possibility, and signal integrity analysis through equalization and jitter decomposition. The note also covers passive cable characterization using mixed-mode S-parameter analysis on a Vector Network Analyzer (VNA), including eye diagram simulation and TDR-based impedance measurements for standards-compliant DisplayPort PHY validation.
Read Application Note:
