Industry White Paper
Enabling Seamless Ethernet to the Field with 10BASE-T1L Connectivity
July 28, 2020 by Analog Devices
Whitepaper Overview
10BASE-T1L is a new IEEE-approved Ethernet physical layer standard that will dramatically change the process automation industry by improving plant operational efficiency through seamless Ethernet connectivity to field-level devices. Many process automation challenges including power, bandwidth, cabling, distance, data islands, and intrinsically safe Zone 0 (hazardous areas) applications can be solved using this new 10BASE-T1L standard. With 10BASE-T1L, there are more possibilities for data analysis, operational insights, and productivity improvements through a converged Ethernet network from the field to the cloud.
In this whitepaper from Analog Devices, learn more about the benefits 10BASE-T1L physical layer products can bring to the Ethernet realm, especially when used in addition to Analog Devices’ ChronousTM portfolio of Industrial Ethernet solutions.
Read White Paper:
