Industry White Paper
Five key workflows that deliver 3D IC packaging success
Several factors are converging and driving the chiplet design revolution. This paper explores these factors and outlines five key workflows that address and manage the associated, new challenges. The paper recommends workflow adoption focus areas that provide immediate heterogeneous integration capability benefits while establishing a managed methodology adoption and migration process that minimizes disruption, risk, and cost. This will bring heterogeneous integration-based chiplet design within reach of the mainstream instead of being accessible only to the mega iDMs and fabless semiconductor companies.
Topics Covered
Adapting to design with chiplets
Early planning and predictive analysis
Hierarchical co-optimization
Interface management and design
White Paper Overview
The semiconductor industry is facing an inflection point as higher cost, lower yield, and reticle size limitations drive the need for viable alternatives to traditional monolithic solutions, which are hitting or coming close to the limits of manufacturing and physics. This is driving an emerging trend to disaggregate what typically would be implemented as an SoC into solid, fabricated IP blocks, otherwise known as chiplets. These chiplets typically provide a specific function implemented in an optimal chip process node. Several chiplets and an optional, custom SoC device can be mounted and interconnected in a single package using high speed/bandwidth chiplet-tochiplet interfaces. The resulting 3D IC heterogeneously integrated packages deliver greater performance at a reduced cost, higher yield, and have only a slightly larger area than a traditional monolithic SoC package.
This paper explores these new challenges and outlines five key workflows that address and manage them. These five workflows span several interlinked domain areas:
  • Architecture definition
  • Design activities (including planning, prototyping, system technology co-optimization, and detailed physical implementation of the substrates)
  • Multi-physics analysis
  • Device-level test
  • Manufacturing
Read White Paper:
