Industry White Paper
FPGAs vs. eFPGAs: Understanding the Key Differences
As chip architecture evolves toward heterogeneous SoCs and chiplets, engineers face a growing challenge: balancing flexibility with efficiency. Traditional FPGAs remain essential for rapid prototyping and field reconfigurability, but embedded FPGAs (eFPGAs) are increasingly the smarter choice for new chip developments that need to be future-proof. This article breaks down the key differences between FPGAs and eFPGAs, and how QuickLogic’s open, customizable eFPGA IP delivers ASIC-level performance with FPGA-like adaptability.
FPGA vs eFPGA: Two Approaches To Programmable Logic
An FPGA is a standalone, reprogrammable chip that sits on your board. An eFPGA is the same kind of programmable logic fabric embedded as IP inside your custom ASIC or SoC. FPGAs offer maximum flexibility for prototyping; eFPGAs add on-die speed, lower power, a smaller footprint, and lower per-unit cost at volume without giving up reconfigurability.
FPGAs (field-programmable gate arrays) have been the backbone of hardware flexibility for decades. They’re standalone, reprogrammable devices that let engineers iterate quickly, adapt to new standards, and extend product lifecycles through field updates.
An embedded FPGA (eFPGA) takes that same programmable logic fabric — the configurable logic blocks (CLBs), look-up tables (LUTs), DSP blocks, and interconnect — and integrates it inside a custom ASIC or SoC. Instead of mounting a separate FPGA chip on your board, you build the reconfigurable fabric right into your silicon.
QuickLogic’s Australis™ eFPGA IP generator automates the creation of optimized eFPGA fabrics across multiple foundries and process nodes. It gives engineers fine-grained control over array size, routing, and power, while integrating seamlessly with standard ASIC design flows. For aerospace and defense applications, QuickLogic also provides radiation-hardened eFPGA IP that delivers reliable performance in extreme environments.
Learn more: Australis eFPGA IP Generator | Rad-Hard eFPGA IP
The Key Differences Between FPGAs and eFPGAs
1. Integration and form factor
- FPGAs are standalone chips that require board space, I/O pins, and additional power delivery components.
- eFPGAs are IP cores integrated directly into an ASIC or SoC, eliminating external parts and routing complexity, cutting board costs, and shrinking the system footprint.
Result: Lower BOM, improved signal integrity, and simpler supply chain management.
2. Performance and power efficiency
- FPGAs communicate off-chip. Every signal crosses I/O boundaries, adding delay and consuming power.
- eFPGAs communicate on-die, directly with nearby logic and memory blocks, reducing latency and energy consumption.
Result: Higher throughput, lower power, and reduced thermal stress, ideal for real-time AI, sensor fusion, and mission-critical systems.
3. Flexibility and post-manufacturing updates
- FPGAs excel in R&D and prototyping thanks to unlimited reprogrammability.
- eFPGAs bring that adaptability inside the ASIC, enabling updates to algorithms, security logic, or standards after tape-out and extending the product’s life without a redesign.
Result: ASIC-class efficiency with FPGA-style agility for long-lifecycle products.
4. Cost, volume, and supply chain stability
- FPGAs make sense for low- and mid-volume production, where eliminating NRE (non-recurring engineering) cost is key.
- eFPGAs: once designs stabilize and scale, embedding eFPGA logic directly in the SoC reduces per-unit cost and mitigates supply chain risk. There is no separate FPGA sourcing, no part obsolescence, and no multi-vendor logistics.
Result: Predictable supply, smaller BOM, and ASIC economics for high-volume applications.
5. Security and long-term survivability
- FPGAs are more exposed to physical and bitstream-based tampering.
- eFPGAs reside within the SoC’s trusted security perimeter, benefiting from secure boot, encrypted configuration data, and hardware-level authentication. That makes them the go-to choice for systems that must remain secure, upgradeable, and field-resilient over decades of operation.
- QuickLogic’s radiation-hardened eFPGA IP supports secure bitstream updates, tamper detection, and triple-modular redundancy (TMR) strategies to enhance reliability under extreme conditions.
Result: Enhanced security, longevity, and resilience, built into the silicon itself.
6. Mission-specific and regional adaptability
- One overlooked benefit of eFPGA integration is post-production customization. A single SoC design can serve multiple regions, missions, or product variants by reconfiguring the embedded fabric.
- A manufacturer can support different communication standards, encryption algorithms, or hardware feature sets from one base ASIC, without a redesign.
Result: Lower development cost and faster adaptation to changing market or regulatory requirements.
7. Toolchains and ecosystem support
- FPGA tools are self-contained but proprietary.
- eFPGA flows require integration with ASIC design tools, which can sound complex, but QuickLogic has solved that. Our open-source toolchain, built around multiple open-source projects integrated into the Aurora ecosystem, makes eFPGA design accessible, portable, and verifiable.
The Australis IP generator automates creating and characterizing eFPGA blocks for your chosen foundry and process node, delivering custom IP in weeks, not months.
More info: QuickLogic Open-Source Tools
FPGA vs eFPGA at a Glance
| Feature | FPGA | eFPGA |
| Integration | External chip | Embedded IP core |
| Power | Higher (I/O overhead) | Lower (on-die interconnect) |
| Update flexibility | Full field reprogrammability | On-chip algorithm updates |
| Cost (volume) | No NRE, higher per-unit | Higher NRE, lower per-unit |
| Security | Exposed to physical and bitstream tampering | Inside the SoC trusted security perimeter |
| Best suited for | Prototyping and low- to mid-volume production | High-volume, power-sensitive, long-lifecycle systems |
When to Choose FPGA vs eFPGA
- Choose an FPGA for rapid prototyping, early development, or applications requiring frequent in-field updates.
- Choose an eFPGA for higher-volume, power-sensitive, or long-lifecycle systems that benefit from ASIC integration and on-chip reconfigurability.
Many QuickLogic customers prototype in traditional FPGAs, then migrate their logic to a QuickLogic eFPGA IP block for production, preserving flexibility while maximizing performance and cost efficiency.
For more background, see Semiconductor Engineering’s embedded FPGA overview.
Beyond Flexibility: Longevity, Security, and Confidence
Aerospace, defense, and industrial systems must last for decades, often under mission-critical conditions. QuickLogic’s eFPGA IP supports secure lifecycle management, cryptographic agility, and firmware-level adaptability, giving system architects the confidence to update, harden, and future-proof their designs without costly re-spins.
QuickLogic also offers evaluation programs, reference designs, and collaborative partnerships to accelerate adoption, so teams can explore eFPGA integration with minimal risk and maximum support.
Result: Faster design cycles, secure updates, and hardware that evolves with your mission.
The Big Picture: FPGAs and eFPGAs Are Complementary
FPGAs and eFPGAs aren’t competing technologies. They’re complementary tools in the engineer’s toolbox. FPGAs deliver maximum flexibility for fast-moving development; eFPGAs bring that flexibility inside the chip for scalable, efficient, and secure products.
As the semiconductor industry embraces custom SoCs, chiplets, and AI-driven workloads, eFPGAs are emerging as a foundational element, combining performance, adaptability, and design freedom. QuickLogic is empowering engineers in this transition with open, customizable, and secure eFPGA IP, backed by decades of programmable logic expertise.
| Key Takeaway |
| FPGAs and eFPGAs are complementary. Prototype and iterate with an FPGA; choose an eFPGA when production demands ASIC-level power, cost, and security with reconfigurability after tape-out. QuickLogic’s Australis™ IP generator delivers custom eFPGA IP for your foundry and process node in weeks, not months. |
Learn more about QuickLogic’s eFPGA IP, open-source tools, and support programs at quicklogic.com/efpga-ip.
