Industry White Paper
High Performance, Dual IF Sampling Receiver
Dual IF sampling receivers are critical in cellular base stations and wireless systems for converting high-frequency RF signals into precise digital data, while addressing challenges like impedance matching, noise reduction, and antialiasing. In this application note, learn how Analog Devices’ design combines a dual mixer, variable gain amplifier, dual 14-bit ADC, and low-jitter clock synthesizer with a fourth-order antialiasing filter to achieve 153.6 MHz IF sampling at 122.88 MSPS and 79.6 dBc spurious-free dynamic range.
Application Note Overview
Used in cellular base stations, wireless communication systems, and RF test equipment, dual IF sampling receivers are essential for converting high-frequency radio signals into high-resolution digital data streams for signal analysis and processing. This application note examines the architecture of a dual-channel IF receiver—which combines a dual balanced mixer, broadband SAW filter, digitally controlled variable gain amplifier (VGA), dual ADC, and clock synthesizer.
Read this application note from Analog Devices to discover how a dual IF sampling receiver design achieves exceptional performance with a 153.6 MHz IF, 14-bit ADC resolution, and a 122.88 MSPS sampling rate. The solution leverages the ADL5356 dual mixer for RF downconversion, the AD8376 VGA for adjustable gain with high linearity, the AD9258 ADC for precise digital conversion, and an AD9517-4 clock synthesizer for low-jitter timing, all integrated with a fourth-order Butterworth antialiasing filter to ensure high spurious-free dynamic range (SFDR).
The note also highlights how this advanced receiver architecture supports diverse applications, including main/diversity base station receivers, wireless signal monitoring, and RF system prototyping. Features such as 24 dB gain control, 79.6 dBc SFDR, flexible SAW filter bandwidths, and modular component integration make this design a versatile and scalable solution for high-performance RF signal processing.
