Industry White Paper
High-Side Current Sensing: Difference Amplifier vs. Current-Sense Amplifier
High-side current sensing is critical in motor control, solenoid control, and power management applications for accurate load-current measurement while preserving ground integrity and enabling diagnostics. This white paper compares difference amplifiers, like the AD8206, and current-sense amplifiers, like the AD8210, highlighting trade-offs in bandwidth, common-mode rejection, input bias, and voltage-stress tolerance. These architectures support diverse applications—from H-bridge motor control to automotive battery monitoring.
March 01, 2026 by Analog Devices
Topics Covered
How Integrated High-Voltage Difference Amplifiers Work
Effect of External Input Filtering
Overdriving the Inputs
Negative Voltage Protection
Input Bias Current
White Paper Overview
Used in motor control, solenoid control, automotive power management, and battery monitoring, high-side current sensing is essential for accurate load-current measurement while preserving ground integrity and enabling improved diagnostic capabilities. This white paper examines the principles of high-side current monitoring—including unidirectional versus bidirectional sensing, PWM common-mode effects, and the trade-offs between difference amplifiers and current-sense amplifiers—and highlights the technical challenges of maintaining accuracy, bandwidth, and common-mode rejection under real-world conditions.
Read this paper from Analog Devices to discover how integrated solutions improve high-side current measurement using high-performance components such as the AD8206 difference amplifier and AD8210 current-sense amplifier. The designs handle wide common-mode voltage ranges, provide precise differential amplification, and support both instantaneous and average current monitoring while addressing input bias, filtering, and voltage-stress considerations.
The paper also highlights how these sensing architectures support diverse applications, including H-bridge motor control, solenoid actuators, and automotive battery systems. Features such as high input common-mode rejection, low input bias current, robust negative-voltage tolerance, and flexible filtering options make these solutions versatile, scalable, and suitable for both power-sensitive and high-speed current-monitoring applications.
Read White Paper:
