Industry White Paper
Lessons Learned: Developing a 25 kW DC Fast EV Charging Module
onsemi expands its reference design series to offer some tips and tricks for designing and debugging a 25 kW DC fast charger. Read on to learn more!
April 01, 2024 by onsemi
Topics Covered
PFC Stage DESAT Protection
DAB DCDC Stage DESAT Protection Enhancement
PFC Stage SiC PIM Layout
Control Design
Loop−Back Testing
White Paper Overview
In this deep dive into the development of onsemi’s 25 kW DC fast charging reference design, you will learn design tips and tricks from both hardware and firmware perspectives. Supported with waveform analyses, the paper walks you through the design approach and takes you through the debug phase. It explains how you can test and fine-tune short-circuit desaturation protection and reveals the cause of SiC MOSFET drain voltage ringing and the impact of adding a snubber capacitor. Read on to find solutions such as testing Device Under Test (DUT) with lower power equipment and understand Phase Shifted Dual Active Bridge control algorithm design.
Read White Paper:
