Industry White Paper
Powering Industrial Image Sensors Tutorial
Industrial image sensors require carefully designed power trees that deliver low-noise, thermally efficient, and tightly regulated voltage across multiple rails, using combinations of buck converters and LDOs to balance efficiency, accuracy, and heat dissipation. The tutorial explains how to evaluate conduction losses, dropout voltage, transient response, PSRR, and junction temperature to select the right regulators. It offers practical design guidance and real component examples—especially for onsemi Hyperlux sensor.
December 12, 2025 by onsemi
Topics Covered
Key Components of a Regulated, Step-Down Power Supply
How A Buck Converter Works
How A Low Dropout Regulator (LDO) Works
Why Heat Dissipation Is Important
The Role of the Power Tree
Hyperlux CMOS Image Sensors
Optimized Power Design For Better Industrial Imaging
Tutorial Overview
Industrial image sensors rely on dependable power delivery to maintain consistent performance and long-term reliability. Because these sensors operate from several internal supply domains, they need carefully managed voltage levels, making the choice and design of power regulators an important part of system planning.
This tutorial offers a clear, big-picture look at how to build effective power architectures for image sensors. It explains the roles of different types of regulators, outlines what to consider when selecting them, and highlights common challenges such as noise, heat, and varying environmental conditions.
Readers will learn how to put together complete power trees for industrial sensors—including practical examples based on onsemi’s Hyperlux family—and how to choose components that meet performance, thermal, and sequencing needs. The tutorial also provides side-by-side regulator options and component suggestions to help guide design decisions.
Read Tutorial:
