Industry White Paper
Precision Timing in Humanoid Subsystems
Humanoids depend on Precise Timing across processing, perception, communication, and actuation systems, where even small delays can impact stability, performance, and safety. This white paper explores how factors such as vibration, temperature changes, EMI, and network jitter affect synchronization accuracy, and why maintaining a common time reference is essential for reliable sensor fusion and control.
September 13, 2026 by SiTime
Topics Covered
Timing Is a Fixed Budget the Whole System Must Share
Operational Stress Defines the Timing Floor
Central Processing: A Heterogeneous Hierarchy Held Together by a Shared Clock
Clock Synchronization Enables System Reliability
White Paper Overview
Humanoid robots operate within extremely tight control-loop latency budgets, where milliseconds can determine stability, performance, and safety. This white paper examines how timing requirements are distributed across four critical subsystems, central processing, perception, communication, and actuation, and explains why meeting individual subsystem specifications is not enough to guarantee reliable system operation.
The paper explores how various factors such as vibration, temperature variation, electromagnetic interference (EMI), and network jitter can degrade synchronization accuracy and consume valuable timing margin. It highlights the importance of maintaining a common time reference across sensors, processors, networks, and actuators to ensure accurate sensor fusion, deterministic control, and coordinated system behavior in demanding operating environments.
Finally, the paper introduces the concept of a system-level synchronization metric, Total Time Uncertainty (TTU), as a way to quantify timing performance across distributed robotic systems under real-world conditions. By examining timing as a shared resource that spans the entire control chain, the paper provides system architects and design engineers with a framework for building robotic platforms that can achieve reliable performance beyond controlled demonstrations. Download a copy of this white paper now to learn more.
Read White Paper:
