Industry White Paper
Programmable Power Supplies: Enabling Advanced Semiconductor Manufacturing
Advanced semiconductor processes demand precise, stable, repeatable DC power. This white paper explains how programmable power supports critical front-end fabrication and back-end test operations.
White Paper Overview
Programmable DC power supplies enable semiconductor manufacturing by delivering stable, low-noise power with CV/CC/CP modes and closed-loop control via analog programming/monitoring—supporting ion implantation, plasma etch/deposition, burn-in, and ATE.
What You’ll Learn Inside:
• Industry drivers: How semiconductor growth and fab capacity expansion are increasing demand for equipment and test solutions.
• Front-end operations: How programmable supplies support ion implantation with closed-loop control—where failures can mean wafer loss.
• Back-end operations: Why burn-in and reliability test require stable power over long durations plus restart flexibility and remote control.
• Control modes that matter: Where constant voltage (CV), constant current (CC), and constant power (CP) modes are used in semiconductor manufacturing.
• Real-time control: How 0–10V analog programming inputs and monitoring outputs support closed-loop systems.
• Solution mapping: Which high-power DC platforms fit key fab/test applications (air-cooled vs water-cooled vs high-power extensible).
Who Should Download This Whitepaper?
• Semiconductor equipment OEM engineers: Those working on implantation, etch, deposition, and plasma systems.
• Test engineers: Professionals running burn-in, reliability, and functional testing.
• ATE architects: Engineers needing compact, remotely programmable power for high-throughput automated test racks.
• Fab process and operations teams: Groups focused on maximizing yield, ensuring stability, and maintaining uptime.
In semiconductor manufacturing, power instability can impact process consistency and test repeatability. This white paper highlights how programmable power contributes to stable front-end processing and reliable back-end screening.
Download the white paper now and learn how the right programmable power strategy can improve process control, reduce scrap risk, and strengthen reliability testing in semiconductor manufacturing.
