Industry White Paper
Proposed standardization of chiplet models for heterogenous integration
In this paper by Siemens, the authors, as members of the Chiplet Design Exchange (CDX), propose a set of standardized chiplet models that include thermal, physical, mechanical, IO, behavioral, power, signal and power integrity, electrical properties, and test models, as well as documentation to facilitate the integration of the chiplets into a design. Additionally, security traceability assurance is an emerging need to ensure trusted supply chain and operational security of the chiplets and the resulting packaged devices. It is strongly recommended that these models are electronically readable for use in the design work flows.
Topics Covered
What is a chiplet?
The need for chiplet models
Types of chiplet models
Documentation & Guidelines
White Paper Overview
With the economics of transistor scaling no longer universally applicable, the semiconductor industry faces an inflection point as higher cost, lower yield, and reticle size limitations drive the need for viable alternatives to traditional monolithic solutions. What we see is the move to innovative packaging technologies to support system-scaling demands and achieve lower system cost. This is driving an emerging trend to disaggregate what typically would be implemented as a single homogeneous, system-on-chip (SoC) ASIC device into discrete, unpackaged ASIC devices, otherwise known as chiplets. These chiplets typically provide a specific function implemented in an optimal chip process node. Several of these chiplet devices are mounted and interconnected into a single package using high speed/bandwidth interfaces to deliver monolithic or greater performance at reduced cost, higher yield, and lower power with only a slightly larger area than a heterogeneous integrated advanced package.
In this paper, we propose a set of standardized chiplet models that include thermal, physical, mechanical, IO, behavioral, power, signal and power integrity, electrical properties, and test models, as well as documentation to facilitate the integration of the chiplets into a design.
Read White Paper:
