Industry White Paper
Selecting Your Next Oscilloscope: Why Vertical Resolution Matters
See how oscilloscope architecture can uncover low-level ripple, transient glitches and EMI behavior before hidden signal problems lead to redesigns or production failures.
August 03, 2026
by Rohde & Schwarz
Topics Covered
High-Resolution Requirements in Modern Design
Native 12-Bit ADC Architecture
Precision Without Bandwidth or Sample-Rate Trade-Offs
Dynamic Range for Small-Signal Analysis
Low-Noise Measurement of Ripple and Transients
High-Resolution Triggering for Rare Signal Anomalies
White Paper Overview
Vertical resolution is a critical factor in oscilloscope performance, directly affecting measurement accuracy beyond bandwidth and sample rate. This white paper explains how higher vertical resolution improves signal fidelity and helps engineers make more accurate measurements in power electronics and high-speed digital applications.
What you'll learn:
- The impact of quantization noise and the benefits of native 12-bit vs. traditional 8-bit architectures.
- The trade-offs of software-based resolution enhancement, including its effect on bandwidth and sample rate.
- How vertical resolution and instrument blind time influence the detection of rare, intermittent signal anomalies.
Error
