Industry White Paper
Silent Switcher µModule Regulators Quietly Power GSPS Sampling ADCs in Half the Space
Discover how Silent Switcher µModule regulators solve complex multirail GSPS ADC power challenges with low EMI and a compact footprint.
June 01, 2026 by Analog Devices
Topics Covered
Low Noise µModule Regulator Architectures
Simplicity and Footprint Considerations
Traditional, Baseline Power Supply System Design
Load Sensitivity to Power Supply Noise
High Efficiency Multirail Power Solutions
PCB Footprint Reduction Techniques
Technical Article Overview
As analog-to-digital converters push into the GSPS range, their power supply requirements become increasingly complex. High speed ADCs may require multiple independent rails at different voltage levels, and supply noise can directly degrade converter performance.
This technical article from Analog Devices examines how Silent Switcher µModule regulators address the multirail power requirements of GSPS ADCs with high efficiency, low EMI, and a compact footprint. It compares conventional switcher-plus-LDO architectures with a simplified µModule-based approach that reduces component count and board area while maintaining dynamic performance.
Engineers designing radar front ends, SDR platforms, test equipment, or high speed data acquisition systems will find the article directly applicable. Use it to evaluate a more compact and efficient approach to powering noise-sensitive GSPS converters.
Read Technical Article:
