Industry White Paper
System Solution Guide: Solar Inverter
Design high-performance solar inverters with confidence. Explore architectures, topology tradeoffs, and device selection strategies to optimize efficiency, density, and cost.
Guide Overview
The Solar Inverter System Solution Guide provides an application‑level blueprint for designing high‑efficiency PV inverters across micro, string, and utility‑scale architectures. It details the implementation of the DC‑DC boost and DC‑AC inverter stages, outlines key topology decisions—including active neutral‑point clamped (A‑NPC) vs. improved NPC (I‑NPC)—and maps these to device choices spanning EliteSiC MOSFETs, FS7 IGBTs, and hybrid power modules.
The guide discusses when SiC enables higher switching frequency and reduced passive size for increased power density, and where IGBTs remain optimal at very high current levels. It also compares module vs. discrete implementations, provides gate driver selection guidance, and includes block diagrams, recommended components, and development resources to shorten time‑to‑design. This system‑level perspective equips engineers to balance efficiency, thermal performance, BOM cost, and scalability in next‑generation solar inverter platforms.
