Industry White Paper
Thermal Calculations for IGBTs
High-power designs, such as power conversion circuits found in EV charging, solar farms, and energy storage, often use IGBT switches. Understanding power dissipation and its impact on the device die is critical in establishing safe temperature limits and ensuring reliable system operation.
May 23, 2023 by onsemi
Topics Covered
Loss Components
IGBT and Diode Power Calculations
IGBT
Die Temperature Calculations
Application Note Overview
The safe and reliable operation of high-power conversion circuits requires an understanding of junction temperature. However, the IGBT switches commonly used in such circuits require a complex set of calculations to determine die temperatures because they are often co-packaged as IGBT and diode dies. This requires that you know the power dissipation, frequency, thermal resistance values (and interaction coefficient for each die.
This paper teaches you how to measure the power dissipation of each device using waveforms from a digital oscilloscope and calculate their average and peak junction temperatures given thermal resistances and interaction coefficient of the IGBT.
Read Application Note:
