Industry White Paper
Using ADI Trinamic’s IC Software API and Examples
This application note from Analog Devices explains how to use the Trinamic TMC-API to simplify firmware development for motion control ICs in embedded and industrial systems. It outlines development setup, build, flashing, and debugging workflows using tools such as J-Link and DAPLink, along with integration into evaluation platforms like the LandungsbrueckeV3. The note also introduces PyTrinamic for Python-based scripting and rapid prototyping, enabling scalable and portable motion control firmware development.
Application Note Overview
Aimed at embedded motion control systems, industrial automation platforms, and motor-drive development environments, this application note Analog Devices explains how to implement the ADI Trinamic TMC-API to accelerate firmware development for motion control ICs. The document outlines the portable C-based API structure, including register-level abstractions, hardware abstraction layers, and SPI communication functions, along with integration into evaluation platforms such as the LandungsbrueckeV3 for Cortex-M–based systems.
Download this application note to learn how to configure development environments using Eclipse, the GNU Arm Embedded Toolchain, and TMCL-IDE, and how to build, flash, and debug firmware through both bootloader and direct programming methods. The guide details practical workflows using tools such as J-Link and DAPLink, including setup for Windows and Linux, GDB-based debugging, and terminal-based flashing via pyOCD.
The note also introduces PyTrinamic, a Python-based scripting alternative to TMCL-IDE that enables rapid prototyping and automated evaluation of supported devices.
