GaN Transistors Double Down on Size and Power Efficiency
Whether in space or on the ground, these GaN-based transistors unlock new benefits compared to silicon.
News September 27, 2023 by Aaron Carman
Three organizations have released new GaN power transistors last month that make considerable strides in efficiency, robustness, and applicability for unique environments.
New GaN-based devices offer improved efficiency
New GaN-based devices offer improved efficiency, robustness, and control in smaller packages. Image used courtesy of Transphorm
The power electronics field imposes unique demands on the next generation of high-voltage, high-current transistors—particularly for switching power supplies or motor drives. As such, new GaN transistors allow electronics to operate in new environments with comparable performance to SiC or IGBT technology.
This article takes a closer look at three summer releases of GaN transistors and gives readers a sense of how each one can benefit designers and shape the future of high-power devices.
Transphorm Focuses on Robustness in New GaN Transistor
Kicking off this roundup is the latest GaN power transistor from Transphorm, with a reported short-circuit robustness of up to five microseconds for future power inverters. As electric motors become more commonplace, many designers are concerned about the ability of GaN power electronics to withstand short circuit scenarios with both high voltage and current. To this end, Transphorm claims its power transistor is an important step toward robust GaN inverters.
Transphorm cascode GaN FET offers improved immunity
Compared to traditional e-mode FETs, the Transphorm cascode GaN FET offers improved immunity and robustness for high-reliability applications such as EVs or power inverters. Image used courtesy of Transphorm
When responding to short circuits, a system’s control electronics may take up to a few microseconds to remove power. As a result, the power electronics must withstand the short until power is removed. Previous generations of GaN devices have only shown short circuit robustness on the order of hundreds of nanoseconds, limiting the practical application of GaN devices. With the latest Transphorm device, however, designers can now remove power before any transistors are irreparably damaged.
Transphorm plans to present more details about the transistor at a major power electronics conference in 2024. We do know, however, that the transistor itself uses a cascode architecture to improve the robustness of the device and offer other improvements compared to enhancement-mode devices.
EPC Space Brings GaN to the Edge of the Atmosphere
Bringing GaN to the final frontier, EPC Space introduced two new radiation-hardened GaN transistors for high-current switching in space-based applications. As the number of commercial satellites continues to increase, designers require more options for space-ready power electronics with improved current handling.
The EPC Space GaN transistors
The EPC Space GaN transistors offer designers improved performance via GaN’s physical benefits in a hermetic rad-hard package purpose-built for space applications. Image used courtesy of EPC Space
The two new transistors, the EPC7020G and EPC7030G, are housed in hermetic packaging for a small yet robust footprint. Both can handle 200 A pulses and join the existing EPC70XX family of GaN transistors.
The EPC7020G can withstand up to 200 V with a 14.5 mΩ on resistance, and the EPC7030G withstands 300 V with a 32 mΩ on resistance. While EPC Space targets power supplies, motor drives, and various other instrumentation tasks as primary beneficiaries of the new rad-hard GaN devices, applications could extend far beyond those listed if the GaN devices show enough improvement over rad-hard silicon MOSFETs.
Rohm Hones In on GaN Miniaturization
Finally, in an effort to improve both power and area efficiency, Rohm Semiconductor has developed two 650 V GaN power stages with built-in GaN HEMTs and gate drivers for smaller and simpler solutions compared to silicon.
Both of the new power stages, the BM3G007 and BM3G015, support up to 650 V with a corresponding 70 mΩ and 150 mΩ on resistance, respectively. Where the new chips shine, however, is the improved efficiency compared to their silicon counterparts.
Rohm EcoGaN power stages
Rohm EcoGaN power stages offer designers improved efficiency in a smaller overall size, paving the way for new applications using GaN power electronics.  Image used courtesy of Rohm Semiconductor
Rohm has reported a 55% lower loss and 99% reduced volume when using its power stage ICs compared to discrete silicon FETs, giving much more headroom when designing compact electronics. GaN’s inherently faster switching speeds simultaneously reduce the size of the GaN devices and external passive components.
Both power stages are available now, alongside evaluation boards for the modules.
The GaN Maturation Process Continues
Although GaN isn’t a one-size-fits-all solution for electrical engineers, its physical differences compared to silicon certainly make it a viable contender for smaller and more efficient power electronics. Especially when comparing the relative ages of silicon and GaN-based devices, GaN still has a bright future of innovation ahead. As GaN processes mature, the material itself may form the foundation for more efficient power supplies, motor drives, and many more high-power electronics.
