SMK Rethinks Energy Storage With Solar-Powered Coin Cell Battery
HarvestLoop is a sensor-rich energy module that harvests light, supports wireless power transfer, and communicates via BLE, all within a CR2032-compatible form factor.
At CES 2025, SMK Electronics revealed a promising prototype for the future of compact power systems with its Self-Contained Power Supply (SCPS) Coin Battery Module, dubbed HarvestLoop. SMK’s new module stands out for reimagining a well-worn standard—the CR2032 coin cell—by transforming it from a simple energy store into a smart, self-reliant subsystem.
SMK says HarvestLoop is the "industry’s first energy harvesting module to replace the CR2032 coin cell battery."
Roughly the size of a nickel, HarvestLoop combines ambient energy harvesting, wireless power reception, Bluetooth Low Energy (BLE) 5.3 connectivity, and embedded sensing in a compact package designed for low-power, long-lifespan devices. The module signals a larger shift toward power solutions that not only fit within modern electronics but unlock new use cases, trim maintenance burdens, and reduce environmental impact.
Energy Independence in a Coin-Sized Package
The HarvestLoop module fits into CR2032-compatible sockets, maintaining the same 20-mm diameter and 3.2-mm height, while incorporating layers of functionality that extend far beyond conventional coin cells.
Energy is collected through a photovoltaic layer based on Exeger's Powerfoyle technology. SMK optimized this layer to generate electricity from both indoor and outdoor light sources. This harvested energy charges a 4-mAh, solid-state EnerCera battery developed by NGK, enabling stable 3-V output even when light is intermittent. SMK further mitigates low-light limitations by including a wireless power transmission (WPT) pathway. Using a 915–920 MHz antenna, the module can receive microwave energy over several meters, offering a secondary power source when sunlight or ambient light is unavailable.
The module was named a CES 2025 Innovation Award honoree in the Sustainability & Energy category.
Beyond energy storage, the SCPS module incorporates BLE 5.3 for low-power wireless communication and a suite of onboard sensors including an accelerometer, temperature and humidity detectors, and a magnetic sensor. This level of integration effectively turns the battery into a sensor platform and telemetry hub. It no longer simply powers a device but becomes part of the device’s intelligence, capable of reporting its own status and surrounding conditions. For developers and product engineers, this provides a new kind of design building block—one that enables products to harvest their own energy, communicate usage and environmental data, and operate for years without intervention.
Toward Smarter, Greener Power Architectures
SMK’s HarvestLoop converges energy harvesting, communication, and sensing in a ubiquitous and compact format. Disposable CR2032 batteries are currently produced by the billions each year, most ending up in landfills. By eliminating the need for frequent replacements and reducing reliance on lithium mining and global battery logistics, SMK’s module offers an alternative that is both more sustainable and more intelligent. Industry recognition has already followed: The module was named a CES 2025 Innovation Award honoree in the Sustainability & Energy category, validating its technical merit and market potential.
The implications of HarvestLoop’s architecture ripple across a broad spectrum of use cases. In consumer electronics, the 4-mAh battery is well-suited to low-power wearables, remote controls, smart cards, and input peripherals, which typically suffer from battery replacement fatigue. SMK has already demonstrated the technology in a solar-powered remote control for air conditioners and continues to explore custom integrations with partners in automotive, healthcare, and smart infrastructure markets.
All images used courtesy of SMK.
