Digital Circuits
Numeration Systems
19 questions By Tony R. Kuphaldt
Page 1 of 7 0 of 19 answers revealed (0%)
  • Question 1 of 19
    Digital computers communicate with external devices through ports: sets of terminals usually arranged in groups of 4, 8, 16, or more (4 bits = 1 nybble, 8 bits = 1 byte, 16 bits = 2 bytes). These terminals may be set to high or low logic states by writing a program for the computer that sends a numerical value to the port. For example, here is an illustration of a micro controller being instructed to send the hexadecimal number F3 to port A and 2C to port B:
    Suppose we wished to use the upper four bits of port A (pins 7, 6, 5, and 4) to drive the coils of a stepper motor in this eight-step sequence:
    Step 1:
    0001
    Step 2:
    0011
    Step 3:
    0010
    Step 4:
    0110
    Step 5:
    0100
    Step 6:
    1100
    Step 7:
    1000
    Step 8:
    1001
    As each pin goes high, it drives a power MOSFET on, which sends current through that respective coil of the stepper motor. By following a “shift” sequence as shown, the motor will rotate a small amount for each cycle.
    Write the necessary sequence of numbers to be sent to port A to generate this specific order of bit shifts, in hexadecimal. Leave the lower four bit of port A all in the low logic state.
    Reveal answer
  • Question 2 of 19
    The numeration system we use in our daily lives is called base ten, also called decimal or denary. What, exactly, does “base ten” mean?
    Given the following base-ten number, identify which digits occupy the “one’s place,” “ten’s place,” “hundred’s place,” and “thousand’s place,” respectively:
    5,183
    Reveal answer
  • Question 3 of 19
    Observe the following sequence of numbers:
    00
    01
    02
    03
    04
    05
    06
    07
    08
    09
    10
    11
    12
    13
    14
    15
    16
    17
    18
    19
    20
    21
    What pattern(s) do you notice in the digits, as we count upward from 0 to 21 (and beyond)? This may seem like a very simplistic question (and it is!), but it is important to recognize any inherent patterns so that you may understand counting sequences in numeration systems with bases other than ten.
    Reveal answer
Related Tools:
