How Low-Voltage GaN FETs Are Enabling Multi-kW 800 V Isolated Converters
Learn how EPC’s multi-stage ISOP architecture uses low-voltage GaN FETs to efficiently convert 800 V DC in AI data centers, reducing output ripple and capacitance while achieving up to 98.5% efficiency.
Industry Article September 24, 2026 by Maurizio Di Paolo Emilio, EPC
The increasing adoption of 800 V power distribution in AI data centers and industrial automation is creating a new challenge for power-conversion designers: how to convert high-voltage DC efficiently into the 6 V, 12 V and 48 Vrails required by modern loads while maintaining high power density.
A presentation by Michael de Rooij of Efficient Power Conversion (EPC) (see video below) examines how a multi-stage Input Series, Output Parallel (ISOP) architecture can distribute the high-voltage input across several conversion modules, enabling low-voltage GaN FETs to be used on both the primary and secondary sides of multi-kilowatt isolated converters.
Presentation by EPC’s Michael de Rooij
Rather than relying on high-voltage devices for the primary stage, the approach divides the 800 V input among multiple modules. Because each module handles only a fraction of the total input voltage, lower-voltage GaN devices can be used while retaining galvanic isolation, high efficiency and high power density. The presentation also examines how interleaving, planar magnetics and modularity contribute to reducing losses and improving thermal management.
From Two-Stage HV Conversion to Multi-Stage ISOP
In a conventional high-voltage implementation, a two stage ISOP converter can use 650 V GaN FETs on the primary side, with low-voltage devices on the secondary. The alternative presented by EPC divides the high-voltage input across multiple modules, allowing lower-voltage GaN FETs to be used on the primary side as well. The ISOP architecture therefore becomes a scalable platform in which the input voltage is distributed among several series-connected modules, while their outputs are connected in parallel.
This architectural change provides several advantages. Heat generation is distributed across multiple modules rather than concentrated in a small number of high-voltage switching devices. Interleaving further reduces output-current ripple, lowering the capacitance required at the output.
The presentation gives a particularly striking example. For a 6 kW conversion system, peak capacitor current ripple falls from approximately 754 A in a single-phase implementation to 155 A with two phases and 36 A with four phases. Correspondingly, the indicated output capacitance decreases from 387 µF to 39 µF and then just 4.5 µF.
The multi-stage structure also simplifies the magnetic components. Lower voltage conversion stages require fewer transformer turns, making planar magnetics and PCB-integrated structures more practical. Lower switching voltage also reduces differential-mode E-field EMI, while the lower RDS(on) available from low-voltage GaN devices can improve conduction performance.
Comparing conventional two-stage HV ISOP conversion with a multi-stagearchitecture based on low-voltage GaN FETs.
Figure 1. Comparing conventional two-stage HV ISOP conversion with a multi-stage architecture based on low-voltage GaN FETs.
Multi-stage ISOP can use phase interleaving to dramatically reduceoutput-current ripple and required capacitance.
Figure 2. Multi-stage ISOP can use phase interleaving to dramatically reduce output-current ripple and required capacitance.
6 kW From 800 V in an 8 mm Form Factor
The first hardware example is the EPC91123, an eight-module ISOP converter designed to convert 800 VDC to 12.5 VDC at 6 kW using a fixed 64:1 ratio. The system switches at approximately 1.1 MHz and occupies 4,982 mm², corresponding to 830 mm²/kW, with a maximum thickness of only 8 mm while utilizing top-side only cooling. Each of the eight modules delivers just 750 W.
The individual LLC modules use 150 V rated EPC2305 GaN FETs on the primary side and 40 V rated EPC2366 devices on the secondary side, with two secondary FETs in parallel. The transformer modules are implemented on a 14-layer PCB, while a six-layer motherboard provides the system-level interconnection and control.
The measured system performance demonstrates the potential of the architecture. Under 800 V input and 12.5 V output conditions, the converter was tested to 6 kW using only forced-air cooling and without a heatsink attached. The reported efficiency reaches 98.1% peak, remaining at approximately 97% at 500 A output current (6 kW).
The eight-module EPC91123 converts 800 VDC to 12.5 VDC at 6 kW in an 8mm-thick form factor.
Figure 3. The eight-module EPC91123 converts 800 VDC to 12.5 VDC at 6 kW in an 8 mm-thick form factor.
Integrated Magnetics Push Power Density Further
A second design, the EPC91134, extends the concept to an 800 V-to-50 V conversion stage capable of delivering 11 kW. Here, EPC integrates the magnetics of two ISOP modules, allowing the primary sections to share a single magnetic core while using a combined secondary structure.
Each module processes 2.75 kW from 200 V to 50 V. Two modules can therefore deliver 5.5 kW from 400 V, while four modules form the complete 800 V-to-50 V, 11 kW system. The resulting converter occupies approximately 4,800 mm², or 436 mm²/kW, and operates at 1.1 MHz.
The integrated magnetic structure is important because it increases power density without simply adding more semiconductor devices while significantly improving the magnetic core utilization. The presentation also reports effective current sharing between the magnetically coupled sections and an efficiency advantage compared with two separate modules. The measured system reaches 98.5% peak efficiency, and 98% at 220 A output, under forced-air only cooling.
Magnetic integration enables the EPC91134 to deliver 11 kW from an 800V input to a 50 V output.
Figure 4. Magnetic integration enables the EPC91134 to deliver 11 kW from an 800 V input to a 50 V output.
Measured EPC91134 efficiency reaches 98.5% under 800 V-to-50 Voperation at up to 11 kW.
Figure 5. Measured EPC91134 efficiency reaches 98.5% under 800 V-to-50 V operation at up to 11 kW.
Regulation Remains the Critical Design Challenge
Fixed-ratio conversion is particularly attractive for maximizing efficiency, but real systems still need to accommodate input-voltage variations. Regulation normally introduces additional components, losses and control complexity, while the isolation requirement prevents some partial-power approaches from being utilized.
For the relatively narrow ±5% input-voltage range considered in the presentation - equivalent to ±40 V around an 800 V bus - three approaches are proposed.
The first regulates only one module, using a pre-regulator and leaving the remaining modules at their optimum fixed-frequency, fixed-duty-cycle operating point. A back-to-back converter can provide the required adjustment while minimizing inductor ripple and size.
The second replaces one module with a regulated isolation stage, such as a Dual Active Bridge or Phase-Shift converter. This provides regulation while keeping the other seven LLC modules at maximum efficiency, although the approach requires additional switching devices and has a greater impact on power density due to poor transformer utilization.
The third option regulates all LLC modules. Because LLC converters provide useful regulation only over a relatively narrow range, the approach is best suited to the limited voltage variation considered. Careful design of the magnetizing-to-resonant inductance ratio helps maintain voltage balancing while keeping efficiency high.
A Different Path to 800 V Power Conversion
The central proposition is therefore architectural rather than simply device-driven. By distributing voltage across multiple ISOP stages, low-voltage GaN FETs can become practical switching devices even inside high-voltage, multi-kilowatt isolated converters. The resulting combination of lower conduction resistance, interleaving, distributed thermal loading, planar magnetics and modularity offers a route toward higher efficiency and power density.
The demonstrated 6 kW 800 V-to-12.5 V and 11 kW 800 V-to-50 V platforms show how the concept can scale across different voltage and power requirements. The remaining challenge in some applications is to add the necessary regulation without sacrificing the efficiency and density advantages that make the multi-stage architecture attractive.
All images used courtesy of EPC.
