What CAM and DFM Reviews Reveal Before Multilayer PCBs Enter Production
Explore common design-to-manufacturing gaps observed during pre-production engineering checks of FR-4 boards, from stackup imbalances to tight clearances.
Industry Article September 01, 2026 by Hackett Wang, AIVON
A PCB design can be electrically correct yet still create significant problems during fabrication. Many of these problems are not discovered on the production line. They are identified earlier, during the engineering review that converts design files into manufacturing data.
This pre-production review, often involving CAM and DFM checks, is where design intent meets process capability. On multilayer FR-4 boards in particular, several recurring issues tend to emerge. Understanding these issues helps designers anticipate constraints before they become costly delays or rework. As layer counts increase and layouts become denser, more manufacturing interactions typically need to be considered during engineering review.
Why Pre-Production Review Matters
When design files are submitted for fabrication, the engineering team examines them against process limits: minimum feature sizes, copper distribution, via treatment consistency, edge clearances, solder-mask openings, and stackup symmetry. The goal is not to reject designs, but to identify conflicts that will affect manufacturability, reliability, or visual quality.
Many of these conflicts are invisible in the design software. A layout that looks clean on screen can still hide problems, such as copper distribution imbalances that only appear under lamination pressure, or feature sizes below the fabrication process’s practical limits. These issues surface when the files are evaluated against real process capability, material behavior, and equipment constraints. Addressing them at this stage is almost always faster and less expensive than correcting them after lamination or surface finish.
Recurring Categories of Issues
Several categories of problems appear repeatedly during review of multilayer FR-4 boards. In this section, we’ll take a deeper look at these four common issues:
  1. Stackup construction and copper balance
  2. Feature sizes that fall below process capability
  3. Inconsistencies between layers
  4. Clearance and edge-related risks
Asymmetric stackups or large differences in copper coverage between corresponding layers can cause warpage, registration shift, and thickness variation after lamination, and these effects are often more pronounced on six-layer boards. This happens because copper and dielectric materials expand and contract at different rates during the heat-and-pressure lamination cycle.
When copper distribution is significantly uneven across the stack, internal stresses build up. The board can develop excessive bow and twist, registration variation between layers, or finished-thickness deviations. Figure 1 illustrates balanced and unbalanced copper distributions in a six-layer stackup. Large imbalances between corresponding layers can contribute to warpage and registration issues during lamination.
Figure 1. Example of balanced (left) versus unbalanced (right) copperdistribution in a six-layer stackup.
Figure 1. Example of balanced (left) versus unbalanced (right) copper distribution in a six-layer stackup. [click to enlarge]
In practice, engineers frequently adjust customer-supplied stackups that deviate from process-proven symmetric constructions, improving overall stackup balance and lamination stability while still meeting the target finished thickness. Aligning the dielectric sequence and copper distribution with a more symmetric, manufacturable configuration is one of the most effective ways to reduce these risks before lamination begins.
Silkscreen characters are a common example. On dense boards, character widths and heights sometimes approach the practical lower limits of reliable reproduction. At some fabrication facilities, line widths around 0.1 mm and character heights around 0.7 mm may already be near the limit for clean printing.
When the layout is crowded with pads and plugged vias, there is often no free space to enlarge or relocate the legend. In Figure 2, the silkscreen characters approach practical process limits on a dense six-layer board with limited free space for enlargement. The risk is blurred or incomplete markings that reduce traceability and can lead to visual rejection, especially on prototype or low-volume lots where appearance is closely scrutinized.
Figure 2. Silkscreen characters approaching practical process limits.
Inconsistencies Between Layers
Paste-layer openings that do not match solder-mask openings—especially at fiducials—can create incorrect solder volume or impaired recognition during assembly. Via treatments also frequently create conflicts. When resin plugging is specified for certain vias but the Gerber data shows single-sided solder-mask openings on those same vias, this can increase the risk of incomplete plugging, resin overflow, or surface planarity issues. These conflicts become more noticeable on boards that already use plugged vias, because the surface topography is more complex and less forgiving of mismatched openings.
Clearance and Edge-Related Risks
Copper features or holes placed too close to the final outline, as demonstrated in Figure 3, increase the chance of breakout or exposed copper after routing. In some cases, copper that falls within the routing-process tolerance must be pulled back to maintain a reliable clearance and prevent exposed copper or other edge-related defects after board separation. Solder-mask bridges that become too narrow after process compensation may also result in incomplete coverage.
Figure 3. The copper on this board edge is too close to the outline.
These issues are not theoretical. They are patterns that surface repeatedly during engineering review of multilayer boards.
A Concrete Illustration
One representative case involved a compact 6-layer FR-4 board measuring 66 × 75 mm, with a 1.2 mm finished thickness, TG150 material, 1 oz copper, and aluminum-plugged vias. During CAM review, silkscreen characters approached the practical lower limits for reliable reproduction. The dense pad layout left no space for enlargement. In addition, several paste openings, including those at fiducials, did not match the solder-mask openings.
Because the board already used aluminum-plugged vias, the surface was relatively complex. There was little room to move or enlarge the legend without overlapping copper or mask features. The fabrication team issued an engineering clarification request documenting the process limits and asking the customer to either accept the expected appearance of the legend or provide an updated silkscreen file. Confirmation was also obtained on the treatment of paste-to-mask openings. Once the customer responded, the files were finalized, and the board proceeded to production without delaying the original schedule.
The case is modest in scale, yet it demonstrates a broader principle: issues identified during engineering review are far easier to resolve before materials are committed than after lamination or surface finish. The same review process that catches silkscreen and paste-mask conflicts is also the stage at which stackup balance, via treatment consistency, and edge clearances are typically examined.
Practical Implications for Designers
The most effective way to reduce these conflicts is to treat manufacturing constraints as design inputs rather than after-the-fact checks. When the following considerations are addressed early, fewer clarification cycles are typically required. This reduces the risk of fabrication delays or rework. The review stage exists precisely to surface these issues while changes are still relatively inexpensive.
Balance Layer Symmetry
Design stackups with reasonable symmetry and copper distribution across corresponding layers. Large imbalances between layers that sit opposite each other in the stack are more likely to generate stress during lamination. Aligning with process-proven constructions often improves both dimensional stability and lamination stability.
Plan Silkscreen Early
Keeping silkscreen characters above practical process limits and reserving clear space for legend on dense boards. When the layout is already filled with pads and vias, there is often no opportunity to enlarge characters later.
Align Mask and Paste Openings
Aligning paste openings with solder-mask openings, particularly at fiducials. Mismatches here can affect both solder volume and machine recognition during assembly.
Harmonize Via and Mask Systems
Defining via treatment and solder-mask openings as a coordinated system. Resin-plugged vias that receive single-side or inconsistent mask openings frequently create planarity or solderability problems.
Respect Edge Clearances
Maintain process-capable clearances from copper features and holes to the board outline. Features placed too close to the edge increase the risk of breakout or exposed copper after routing.
Table 1. Design review matrix
Design Consideration Risks if Overlooked Recommended Approach
Stackup symmetry & copper balance Warpage, registration shift Aim for reasonable balance across layers
Silkscreen size Blurred or incomplete legend Stay above practical process limits
Paste vs. solder-mask openings Incorrect solder volume / fiducial issues Align openings, especially at fiducials
Via treatment + mask openings Planarity/solderability problems Define them as a coordinated system
Edge clearances Breakout or exposed copper Maintain process-capable distance to outline
Closing the Loop Between Design and Fabrication
The gap between a design that is electrically correct and a board that is manufacturable is often narrower than it appears. Many of the problems that surface during fabrication can be identified—and resolved—during the engineering review that precedes production.
Stackup balance, feature-size limits, layer consistency, via treatment, and edge clearances are all examined at this stage. Addressing them before lamination helps protect the production schedule and reduce the risk of rework.
If you would like to learn more, check out AIVON's engineering case studies, where you can find additional examples of these design-to-manufacturing interactions. The case studies identify the engineering constraints and how they were resolved.
