Advanced PCB Manufacturing, Assembly, and More—a PCBWay Company Profile
In this article, we explore the PCB services, intelligent production process, quality strategies, and more offered by PCBWay.
News October 30, 2024 by Jeff Child
At All About Circuits, our mission is to inform and educate readers like you on the latest and greatest services, products, and technology trends in electronics. With that in mind, company profile articles like these let you know the options available for your next design, in this case for PCBs and related services.
At electronica 2024, All About Circuits Editor-in-Chief Jeff Child meets with Simon Gao, Marketing Supervisor & Customer Experience Manager of PCBWay.
Here, we profile PCBWay, a quick-turn PCB prototyping, PCB assembly, and low-volume production manufacturer located in Shenzhen, China.
Overview of PCBWay Services
A multilayer PCB manufacturer, PCBWay claims to offer the fastest PCB lead time of 12 hours. The company supports advanced designs with demanding requirements, including FR4, FPC, aluminum, Rogers, HDI, Flex-Rigid, laser drilled microvias, 6-ounces of heavy copper, pads, microwave and RF boards, and PCBs of up to 24 layers.
PCBWay also provides turn-key PCB assembly services in prototype quantities or low-volume to mid-volume production runs. The firm handles the whole process including: ordering all the components, PCB manufacturing, PCB assembly, testing, and final shipment. PCBWay is capable of assembling boards with BGA, Micro-BGA, QFN, and other leadless package parts.
Intelligent Production and Data Analysis
A key way PCBWay differentiates itself is its use of intelligent production and data analysis in its production processes. Leveraging on-line order capabilities, the company’s process leverages data flow, intelligent services, and efficient collaboration.
This data center at PCBWay’s production facilities makes use of intelligent production practices and data analysis.
The company’s order management system supports automatic data detection and pricing with the uploading of PCB files. Engineer customers can place orders on-line easily and track the progress of their products at any time. PCBWay’s customer service team leverages its self-developed service management system to ensure that PBCWay responds to users within 5 minutes. Flexible shipping methods included DHL, FedEx, EMS, and others.
PCBWay’s Manufacturing Facility and Production Equipment
PCBWay’s production facilities in Shenzhen, China make use of the most advanced equipment available for PCB fabrication, assembly, and its other services. In order to ensure the best quality and reliability of PCB products, PCBWay says that it continuously introduces new advanced equipment into its production line.
In its factory, PCBWay uses the most advanced production equipment available. Shown here are LDI laser exposure machines in the production line.
The systems include, but are not limited to, the following:
  • LDI exposure machines
  • Automatic solder mask production lines
  • Fully automatic PCB testing machines
  • Fully automatic PCB etching equipment
  • Automatic silk screen printing production lines
  • Fully automatic electroplating line
PCBWay’s Production Process
Making a PCB is a complex process with many steps. And every PCB is unique which means a production line has to be able to meet the needs of a wide range of requirements. With all that in mind, now let’s take you through a step-by-step of PCBWay’s process for creating a multilayer PCB.
This graphic illustrates the 18 steps a PCB goes through in PCBWay’s product process.
This graphic illustrates the 18 steps a PCB goes through in PCBWay’s product process. (Click on image to enlarge)
Step 1—Pre Production Engineering: Customer supplied data (gerber files) are used to produce the manufacturing data for the specific PCB—artwork for imaging processes and drill data for drilling programs.
Step 2—Board Cutting: PCB production starts with a large piece of sheet material. Under the guidance of manufacturing instructions, the raw material of the PCB (copper clad laminate) is cut into the processing size by automatic cutting machines.
Step 3—Printing the Inner PCB Layers: An image transfer is done of the PCB artwork film using photosensitive dry-film and UV light. Electronic data is sent to the photo plotter, which in turn uses light to transfer a negative image circuitry pattern onto the PCB panel or film.
Step 4—Etching the Inner Layers: Unwanted copper is removed from the PCB panel using etching. Once this copper has been removed, the remaining dry film is then removed leaving behind the copper circuitry that matches the design.
Step 5—Inner layer Automatic Optical Inspection (AOI): An inspection is done of the circuitry against digital “images” to verify that the circuitry matches the design and that it is free from defects. This is achieved through scanning of the board as well as trained inspectors.
Step 6—Lay-Up and Bonding (Lamination): The lamination process consists of placing the internal layers under extreme temperature (375 ℉) and pressure (275- to 400-psi) while laminating with a photosensitive dry resist.
Step 7—Drilling the PCB: Holes are now drilled (using either mechanical or laser drilling), which will create electrical connections within the multilayer PCB. This drilling is optimized in order to achieve registration of all of the inner layer connections.
Step 8—Electroless Copper Deposition: The first step in the plating process is the chemical deposition of a very thin layer of copper on the hole walls. PTH provides a very thin deposit of copper that covers the holes’ walls and the complete PCB panel.
Step 9—Imaging the Outer Layers: This step is similar to the inner layer process, but with one main difference: Dry film is removed where we want to keep the copper/define circuitry so that additional copper can be plated later in the process. See video below.
This video shows the outlier imaging step of PCBWay’s PCB manufacturing process.
Step 10—Plating: This is the second electrolytic plating stage, where the additional plating is deposited in areas without dry film (circuitry). Once the copper has been plated, tin is applied to protect the plated copper.
Step 11—Etching the Outer Layer: Three steps here. The first is to remove the blue dry film. Second is to etch away the exposed/unwanted copper while the tin deposit acts as an etch resist protecting the copper we need. Third step is to chemically remove the tin deposit leaving the circuitry.
Step 12—Outer Layer AOI: Just like with inner layer AOI, the imaged and etched panel is scanned to make sure that the circuitry meets design specs and that it is free from defects.
Step 13—Solder Mask: Solder mask ink is applied over the whole PCB surface. Using artwork film and UV light, certain areas are exposed to the UV and those areas not exposed are removed during the chemical development process—typically the areas that are to be used as solderable surfaces.
Step 14—Surface Finish: Various finishes are applied to the exposed copper areas. This is to enable protection of the surface and good solderability. The various finishes can include a variety of materials.
Step 15—Profile: This is the process of cutting the manufactured panels into specific sizes and shapes based upon the customer design as defined within the gerber data. There are 3 main options available when providing the array or selling panel: scoring, routing, or punching.
Step 16—Electrical Test: Testing is done for checking the integrity of the PCB traces and the via interconnections—checking to ensure there are no open circuits or short circuits on the finished board.
Step 17—Final Inspection: A team of sharp-eyed inspectors give each PCB a final careful check-over. They do visual checking the PCB against acceptance criteria and using PCBWay “approved” inspectors.
Step 18—Packaging: Boards are wrapped using materials that comply with the PCBWay packaging requirements (ESD, etc.) and then they are boxed prior to being shipped.
Quality Assurance for Zero-Defect Products
PCBWay says its approach to quality involves promising zero defect products with on-time delivery. This even factors in the materials they use. The company uses chemically processed copper plating for the production of pads and via metallization, instead of using conductive adhesive technology to save costs.
Each PCB panel must pass 70 minutes of copper plating, AOI, and probe testing. PCBWay says it only uses internationally well-known basic materials such as: Kingboard, Shengyi, TACONIC, Arlon, GDM, TaiYo Ink, and other well-known brands. Meanwhile, the company’s factory has maintained ISO 9001 and UL certification for many years.
The PCBWay ‘Perfect Quality Assurance System’
PCBWay employs a quality assurance process that it calls its “Perfect Quality Assurance System.” The Perfect Quality Assurance System and various testing equipment help the team to monitor the entire production process to ensure the stability of the process and product quality. At the same time, PCBWay also leverages advanced instruments and technical methods to achieve continuous improvement
Here are the key aspects of the system:
PCB File Checking Before Production:  For each order submitted, Gerber files are reviewed by the company’s engineers before being sent to production. Engineers confirm the production feasibility in terms of tolerance constraints such as board edge clearance, drilling, pad spacing, impedance, and routing.
Raw Materials Guarantee: The quality of the raw materials determines durability of the finished products. PCBWay has been working with leading suppliers in the industry and inspects materials according to international standards and customer requirements, such as Shengyi, Rogers, Kingboard sheet, Rohm & Haas, and TAIYO.
Quality Inspection Before Shipment: PCBWay strictly complies with ISO 9001:2015 requirements and all production processes are in line with IPC standards. In addition to basic visual inspections, all boards undergo the most rigorous electrical tests. The company uses industry-renowned testing and inspection equipment.
After the FQC inspection, there are also FQA random inspections, solder mask 3M adhesion tests, slicing tests, and solderability tests.
Strict Management: PCBWay’s quality control systems are regularly audited and assessed to ensure their compliance and effectiveness. A complete quality control system and 100% PCB testing procedures ensure that every order is completed perfectly.
Quality Reports: To ensure that all orders are completed in accordance with the PCBWay manufacturing standards, the company can provide complete quality inspection reports. These include, but are not limited to: Standard Inspection, REACH, Full Dimensional Report, Default Inspection Report, Thermal Stress Test Report, Humidity Indicator Cards, and Microsection Inspection Report.
A Wide Range of Services
Beyond the core business of PCB fabrication, PCBWay offers a wide range of other services. This includes PCB assembly with assembly times ranging from 24 hours to a few weeks. The company also offers high-quality PCB design services along with one-stop shopping OEM electronic manufacturing services, including design, component procurement, PCB manufacturing, patch, plug-in, testing, assembly, and other processes. The company also provides 3D printing and CNC machining services. More detail on those two services below.
3D Printing and CNC Machining
PCBWay has over 50 3D printing machines in its distributed network. They offer a variety of 3D printing technologies including Fused Deposition Modeling (FDM), Vacuum Casting, Selective Laser Melting (SLM), Digital Light Processing (DLP), Stereolithography (SLA), and Selective Laser Sintering (SLS).
PCBWay’s 3D printing and CNC machining services
CNC stands for "computer numerical control" and it's a kind of manufacturing process that instructs the operation of equipment and tools through computer programs. PCBWay’s CNC services enable them to produce machined metal and plastic prototypes or production parts in as fast as two days.
Explore What PCBWay Has to Offer for Your Next Design
Whether it’s PCB manufacturing, PCB assembly, OEM, or 3D printing services, PCBWay has a wealth of services you can leverage for your next system design. Find out more on PCBWay’s website. Also, if you’re attending the Electronica trade show November 12-15 in Munich Germany, make sure to go by and visit PCBWay’s Electronica booth A1-163.
All images used courtesy of PCBWay.
