High-Resolution Multi-Zone Sensing with the TMF8829 Direct Time-of-Flight Sensor
Discover how precise multi-zone direct time-of-flight sensing enables next-generation robotics, automation, AR/VR, and smart devices.
.png)
Webinar Overview
Direct Time‑of‑Flight (dToF) sensing enables precise, real‑time 3D depth measurement for applications ranging from robotics and industrial automation to mobile devices, AR/VR, and smart consumer systems.
In this webinar, ams OSRAM introduces the TMF8829 multi‑zone dToF sensor and explains how it delivers high‑resolution spatial depth data across configurable sensing layouts. With support for resolutions up to 48×32 zones (1,536 measurement points), a detection range of up to 11 meters, 0.25 mm depth resolution, and an 80° field of view, the TMF8829 combines performance and flexibility in a compact 5.7 × 2.9 × 1.5 mm module.
Built on advanced SPAD, TDC, and histogram technology, the TMF8829 performs on‑chip processing to output distance, confidence, and ambient light data, while supporting multi‑object detection, high smudge tolerance, and AI‑ready raw data streaming.
The session will also highlight real‑world application examples, including robotics and scene mapping, gesture recognition, camera autofocus, and smart appliances, demonstrating how high‑resolution dToF sensing enables robust and scalable 3D perception.
Learn more about:
- Fundamentals of direct Time‑of‑Flight (dToF) depth sensing
- Advantages of multi‑zone 3D depth measurement
- Configurable sensing layouts from 8×8 up to 48×32 zones
- Multi‑object detection with high tolerance to cover glass smudging
- On‑chip processing, confidence metrics, and AI‑ready raw data output
- Application examples including robotics, scene mapping, gesture recognition, camera autofocus, and smart appliances
Register now to access the on-demand webinar.
