Jonas Urbonas
Jonas Urbonas
ABOUT
Jonas Urbonas received the B.Eng and Ph.D. degrees in Electronic Engineering from the University of Surrey, Guildford, United Kingdom in 2015 and 2019 respectively. He joined Maury Microwave Inc. in 2019 as a senior product engineer where he specializes in the development of new RF & Microwave device characterization solutions and their applications. Dr. Urbonas has published multiple peer-reviewed publications in various IEEE Journals and is a member of the IEEE Microwave Theory and Techniques, Instrumentation and Measurement, Electron Devices, and Solid-State Circuits societies. In 2019, he was awarded The ARFTG Roger Pollard Student Fellowship in Microwave Measurements and won the best paper and best student paper awards at the 91st and 92nd ARFTG Microwave Measurement Conferences respectively.
mmWave & sub-THz Active Load-Pull, Gain Compression, and S Parameter Measurements
Register and get ideas about mm-Wave and sub-THz active load-pull.
In partnership with Rohde & Schwarz
Webinar Overview
Various applications and systems can support mmW and sub-THz spectrum frequencies. Passive devices, such as filters, splitters, and combiners, and active devices, such as LNAs, PAs, mixers, and receivers, can all potentially support these frequencies. 6G applications are likely to use frequencies above 100GHz, even up to 330GHz, in research.
S-parameters are a key component of measuring and analyzing the characteristics of a device over particular frequencies. Critical specifications like the compression of an amplifier or out-of-band rejection of a filter are derived from S-parameters. Linear small signal device models can also be derived from S-parameters for simulation.
In this webinar from Rohde & Schwarz, viewers will learn how to take S-parameter measurements and complex wave quantity measurements with the ZNA Vector Network Analyzer. The ZNA platform has high dynamic range (140 dB Typ - 170 dB achievable) and measurement speeds of 401 pts @ 32.2 ms. It is available from 10 MHz to 26.5/43.5 GHz.
Free Webinar Registration
