Realizing Extreme High Throughput with Wi-Fi 7
This webinar will give a comprehensive introduction to the new IEEE 802.11be standard and explain the related test challenges and how to solve them.
Webinar Overview
Wi-Fi 6/6E is just entering the market, promising more efficient operation and making use of additional 1.2 GHz of spectrum. However, the demand for much higher data speed and lower latency is unabated. The industry is already working on the next generation of Wi-Fi: IEEE 802.11be or Wi-Fi 7. Wi-Fi 7 is expected to provide data rates as high as 40 Gbps, essentially enabled by use of wide channels, higher modulation schemes and multilink operation. This webinar will give a comprehensive introduction to the new IEEE 802.11be standard and explain the related test challenges and how to solve them.
Learn more about:
- Key features of the IEEE 802.11be standard
- Upcoming test challenges
- Wi-Fi 7 testing solutions for access points and stations
