Arteris Evolves Its Network-on-Chip Tiling to Accelerate AI Designs
The NoC upgrade unlocks new scalability, performance, and power efficiency opportunities.
News October 18, 2024 by Jake Hertz
This week, Arteris announced a significant evolution in its network-on-chip (NoC) IP products, which they claim dramatically enhances the scalability, power efficiency, and performance of system-on-chip (SoC) architectures for artificial intelligence (AI) and machine learning (ML) workloads.
Arteris Network-on-Chip (NoC) IP
Arteris network-on-chip (NoC) IP.
All About Circuits interviewed Andy Nightingale, Arteris’ VP of product management and marketing, and Gina Jacobs, VP of brand marketing, to learn about the new product firsthand.
Modular Scalability Through NoC Tiling
Arteris’ NoC tiling technology can scale without requiring fundamental changes to the SoC architecture. NoC tiling refers to modular, repeatable blocks within the chip called "tiles." Each tile represents a self-contained functional unit that can be duplicated across the chip to meet the computational demands of AI workloads. Replicating these tiles scales performance by more than ten times.
“Network-on-chip tiling effectively enables the partner to the designer to define a module or unit once and then repeat it multiple times within the same chip,” Nightingale said. “That means we can scale up how efficiently a single designer can work and make life easier for them, even though the problems are getting bigger.”
Arteris NoC tiling architecture
Arteris NoC tiling architecture.
Arteris’ FlexNoC and Ncore IP products can scale because of its cohesive tile integration, which supports both non-coherent and cache-coherent interconnects. These architectures ensure data flows efficiently between processing units, such as CPUs, GPUs, and neural processing units (NPUs). The mesh topology is central to this design, allowing each tile to connect with the network interface units (NIUs) and enabling low-latency communication across the SoC. Ultimately, the mesh handles the data transport and simplifies the layout and routing, making it easier for designers to expand the system to meet increased computational demands.
For example, in AI applications such as deep learning and natural language processing (NLP) that require parallel processing, NoC tiling allows system architects to expand the number of processing elements (PEs) without introducing bottlenecks. Each tile is configured to be identical in function, minimizing the complexity that typically arises in large-scale SoC designs. This streamlined integration means that the tiles can be scaled to handle higher data volumes and larger models without significantly increasing the design time.
Power Efficiency and Dynamic Frequency Scaling
As AI workloads become more demanding, optimizing power consumption while maintaining performance is necessary for any computing platform. Arteris' NoC tiling technology includes several features that contribute to significant power savings.
One of the mechanisms employed is dynamic frequency scaling (DFS), which allows different tiles within the network to operate at varying clock frequencies depending on their workload. When certain tiles are not required for processing, they can be powered down.
Although obviously, NoC tiling doesn't directly result in power reduction, it connects to all of the power-saving features that the NoC product provides,” Nightingale explained. “That means that you can have groups of tiles and assign those to specific clock domains. We found that using dynamic frequency scaling in the NPU use case allows us to save an average of 20% processing power by scaling the number of processing elements engaged in particular workloads. ”
Different tiles can operate in varied clock domains
Different tiles can operate in varied clock domains.
The tiling architecture also supports the division of tiles into different clock and voltage domains which allows designers to isolate specific sections of the SoC for independent power management. The mesh topology facilitates this by providing flexible connections between tiles, which can be dynamically activated or deactivated based on workload requirements.
For instance, in a neural network-based AI system, some tiles may handle less intensive tasks like preprocessing while others perform more compute-heavy tasks like model inference. By scaling the power consumption of individual tiles based on their real-time computational load, Arteris’ tiling technology ensures that the SoC maintains optimal power efficiency across various applications.
A Scalable Solution for AI Processing
AI compute applications have distinct requirements regarding scalability, latency, and power efficiency. Arteris’ NoC tiling innovation is well-positioned to meet these needs due to its modular architecture and enhanced data management capabilities.
It's been great to have something to accelerate the AI innovation wave just as it's reaching its apex and we're really pleased that it's finally come out,” Nightingale concluded.
All images used courtesy of Arteris.
