The Evolution of Industrial Sensor Communication: From 4-20 mA to IO-Link
4-20 mA loops sent just one value per line. Discover how HART, Fieldbus, and IO-Link transformed industrial sensors with rich diagnostics, remote configuration, and digital identity.
Technical Article 2 hours ago by Dr. Steve Arar
While industrial controllers began employing digital processing decades ago, many field sensors and actuators continued to communicate with them via analog signals. This constrained the data available to the controller to a single process value per device. A photoelectric sensor could signal a PLC that an object was passing, but it could not report a dirty lens, a rising internal temperature, or an impending failure. A persistent engineering challenge has been to establish a data-rich sensor communication channel capable of carrying diagnostics, device identity, and configuration data. Meeting that challenge drove a multi-decade evolution toward greater data availability, speed, and cost-efficiency.
This article traces that evolution, weighing the strengths and trade-offs of each stage. It begins with the pros and cons of 4-20 mA loops and the hybrid analog-digital solution offered by the Highway Addressable Remote Transducer (HART) protocol. It then examines the architectural shift introduced by fieldbuses to establish a digital backbone, and finally the emergence of IO-Link as a complementary digital solution at the sensor layer.
4-20 mA Loops: Robust by Design, Limited by Nature
A 4-20 mA current loop is an analog signaling standard in which a sensor or transmitter varies the loop current between 4 and 20 mA to represent a process value. For example, in a temperature application spanning 0 to 120°C, 0°C is represented by 4 mA, 60°C by 12 mA, and 120°C by 20 mA.
This scheme has been the foundation of industrial sensing for decades and, despite the rise of digital alternatives, remains one of the most widely deployed signal standards in process control today. Figure 1 illustrates a common scenario: an RTD (resistance temperature detector) sensor connected to a centralized PLC.
Figure 1. A typical industrial process control loop. Image used
courtesy of RealPars.
Figure 1. A typical industrial process control loop. Image used courtesy of RealPars.
Conditioning the RTD Signal
An RTD measures temperature through the resistance of a metal element, typically platinum, which rises predictably as temperature increases. Because this resistance change is small—often less than an ohm to a few ohms per degree—the raw RTD output is highly susceptible to measurement errors. The RTD’s raw output cannot be transmitted directly over long distances to the PLC, because the signal would easily be corrupted by cable resistance and electrical noise.
To protect signal integrity, a temperature transmitter is mounted near the sensor to convert the RTD’s resistance change into a 4-20 mA current loop signal. Transmitting data via current rather than voltage inherently rejects ambient electrical noise due to the loop’s low operational impedance. Furthermore, because Kirchhoff’s Current Law dictates that current remains constant throughout a closed loop, the signal does not drop due to cable resistance even across long runs.
This robust analog signal travels over field wiring to the PLC rack, where an analog input module digitizes the current for the CPU. The CPU executes its control logic based on this precise data and outputs a command back to the process actuators, closing the control loop.
A Loop-Powered Transmitter Example
To see how these principles translate into actual hardware, we examine TI’s reference design, which presents a complete temperature transmitter built around four ICs (Figure 2).
Figure 2. Block diagram of TI’s RTD temperature transmitter. Image
used courtesy of Texas Instruments.
Figure 2. Block diagram of TI’s RTD temperature transmitter. Image used courtesy of Texas Instruments.
The ADS1220 is a 24-bit sigma-delta ADC that excites the RTD with a matched current source and digitizes the resulting voltage—ratiometrically, so the measurement depends on the RTD resistance rather than the exact excitation current.
The MSP430G2513 microcontroller reads that raw ADC code, applies offset and gain calibration, converts the code to a resistance, and performs linear interpolation using a PT-100 lookup table to resolve sensor non-linearity.
The DAC161S997 then converts the temperature value into a 16-bit code that sets the 4-20 mA loop current, with an external transistor regulating the output. To power these blocks, the TPS7A4901 low-dropout regulator steps down the incoming 10–35 V loop supply to derive a 3.3 V rail. This lets the transmitter run completely off the same two wires that carry its output.
Why 4-20 mA Endures
The key advantage of a 4-20 mA current loop is its ability to transmit signals over immense distances. Runs of 1,000 m or more are possible, limited mainly by loop supply voltage and total loop resistance. There is zero appreciable signal loss and inherent immunity to electrical noise. Furthermore, using 4 mA as the lower limit establishes a “live zero” that can power the transmitter while enabling instant fault detection. This lets a PLC immediately distinguish between a valid low reading and a broken wire or dead transmitter, which would drop the loop current to 0 mA. Due to these advantages, 4-20 mA signaling remains the de facto industrial standard over alternative analog options like 0–20 mA or 0–10 V.
HART: Superimposing Digital Data on the 4-20 mA Loop
As industrial processes grew more complex, the limitations of pure analog systems became a critical bottleneck. Control rooms needed more than the raw process variable; they needed device health, calibration data, and secondary diagnostics. Transitioning to a completely new digital infrastructure to achieve this, however, was financially prohibitive. The industry’s answer was the HART protocol, introduced in the mid-1980s as a hybrid analog-digital transition technology.
HART operates by superimposing a low-level AC waveform directly on top of the standard 4-20 mA analog current loop. This waveform shifts between two frequencies to encode the digital bit stream without disturbing the analog process value: 1,200 Hz represents a logical 1, and 2,200 Hz represents a logical 0. This technique of representing digital data through discrete frequency shifts is known as frequency shift keying (FSK). Figure 3 illustrates this concept, showing a 4-20 mA analog curve with the superimposed frequency modulation.
Figure 3. FSK-modulated signal superimposed on a standard 4-20 mA
current loop. Image used courtesy of RealPars.
Figure 3. FSK-modulated signal superimposed on a standard 4-20 mA current loop. Image used courtesy of RealPars.
Because this superimposed AC waveform has an average value of exactly zero, it introduces no net DC offset and therefore does not disturb the underlying analog signal. This electrical transparency is a primary reason for HART’s seamless integration and widespread success. Standard analog I/O cards read the unaltered 4-20 mA process variable without interference. Meanwhile, parallel hardware such as HART multiplexers extracts configuration data, tag numbers, and diagnostic alerts from the digital layer over the same two wires.
By leveraging this digital layer, the controller can query the full suite of secondary process variables and diagnostics that the device provides. It does so without disrupting the primary analog measurement.
While HART successfully unlocks diagnostics over legacy wiring, it introduces two distinct barriers that prevent it from serving as a modern automation backbone. The first is a severe speed limitation: its digital transmission runs at just 1,200 baud, making real-time, high-density telemetry impractical.
The second is an architectural limitation. In its most common configuration, HART remains a point-to-point system, with each device on its own dedicated wire pair running back to the control cabinet. Although the HART specification does support a multidrop mode that shares one pair among several devices, it is rarely used in practice and offers only limited capacity. To overcome these constraints, the industry introduced fieldbus networks as a direct remedy, replacing the sluggish, independent loops with a high-speed, shared digital backbone.
Fieldbus: From Isolated Loops to a Shared Digital Bus
The automation industry rapidly realized that managing complex, high-speed automated systems required a network topology rather than running individual point-to-point wires for every instrument as HART did. By the late 1980s and throughout the 1990s, the "Fieldbus Era" was born. The defining innovation of the fieldbus was a shared digital bus that allowed a single twisted-pair cable to connect multiple field devices in arrangements such as daisy-chain or trunk-and-spur (Figure 4).
Figure 4. Trunk-and-spur topology. Image used courtesy of
Control.com.
Figure 4. Daisy-chain (top) and trunk-and-spur (bottom) topologies. Image used courtesy of Control.com.
By replacing individual cable runs with a single shared wire, fieldbuses radically transformed plant architecture while slashing cabling costs and installation labor. Instead of processing raw electrical currents, the control system communicated via high-speed digital data packets. This shift allowed systems to run fast, real-time control loops. It also provided engineers with multi-variable process data, configuration parameters, and asset-management diagnostics at speeds significantly faster than HART.
“Fieldbus” is a generic umbrella term for a family of industrial digital network protocols designed to replace dedicated point-to-point analog wiring with a digital network infrastructure. It is not a single standard owned by one company but an entire architectural category, encompassing several protocols developed by different automation groups such as Foundation Fieldbus (FF), PROFIBUS (PA and DP), Modbus RTU, and DeviceNet.
While fieldbuses offered clear advantages, they also introduced significant trade-offs in cost and complexity. Deploying a fieldbus network required specialized engineering design, precise line termination, and complex software tools.
Furthermore, the processing power and interface circuitry required to run a full fieldbus protocol imposed a cost and complexity penalty that made sense for a high-end flowmeter but not for a simple proximity switch. This vast economic and architectural gap left the smallest, most common factory floor devices stranded in the analog world—a limitation that ultimately drove the industry to develop IO-Link.
A quick point of clarification: while HART is sometimes grouped with fieldbuses, it remains architecturally distinct. It merely layers digital data on top of an existing analog loop rather than replacing it with a fully digital network infrastructure.
IO-Link: Digital Intelligence at the Sensor Layer
IO-Link is the industry’s answer to a gap that fieldbus left open: the final meters between the control network and the individual sensor. Fieldbuses successfully established a high-speed digital backbone between master controllers and major network nodes. However, they were too expensive and complex to embed in simple, everyday components such as proximity switches, photoelectric sensors, and pressure or temperature transmitters.
Consequently, industrial systems had to rely on a hybrid architecture. A digital fieldbus formed the main network backbone, while traditional point-to-point wiring, such as 4-20 mA loops, covered the final run to the field sensors. This is illustrated in Figure 5.
Figure 5. Integration of Conventional Analog Instruments into a
Digital Fieldbus Network. Image used courtesy of Smar.
Figure 5. Integration of Conventional Analog Instruments into a Digital Fieldbus Network. Image used courtesy of Smar.
The pressure transmitter LD301 communicates via a conventional 4-20 mA current loop, so it cannot connect directly to the Foundation Fieldbus segment. The IF302 converter bridges the two domains—digitizing the analog signal and presenting it to the bus. Therefore, integrating legacy 4-20 mA devices into a fieldbus architecture requires an explicit conversion stage rather than a simple wiring connection.
IO-Link, standardized as IEC 61131-9, is a point-to-point digital communication interface designed specifically for sensors and actuators. It operates over the same unshielded three-wire cables and standard M12 or M8 connectors already used for conventional sensors, meaning no special cabling is required. The basic IO-Link configuration is shown in Figure 6.
Figure 6. Example of IO-Link topology. Image used courtesy of
IO-Link.
Figure 6. Example of IO-Link topology. Image used courtesy of IO-Link.
A smart edge IO-Link device (the sensor or actuator) communicates bidirectionally with a local IO-Link master. The master aggregates the data and bridges it to the higher-level industrial network. IO-Link carries both cyclic process data and acyclic parameters and diagnostics over the same connection. This lets a controller read not just the measurement but the health and configuration of the sensor itself. This bidirectional capability also simplifies maintenance: the IO-Link master can store a device’s parameter set and automatically download it to a replacement sensor, eliminating manual reconfiguration during swap-outs.
The trade-off is scope. IO-Link is deliberately limited to point-to-point connections of up to 20 meters per device, which is why it complements rather than replaces fieldbus networks. Its role in the evolution of industrial sensor communication is therefore best understood as completing the digital chain. Fieldbus brought digital communication to the control architecture, and IO-Link extends that same data richness down to the simplest, most numerous devices in the plant.
Wrapping Up
In this article, we traced industrial sensor communication from a single analog process value on a 4-20 mA loop to a data-rich digital channel carrying identity, configuration, and diagnostics alongside the measurement. HART added digital information to the analog loop, fieldbuses established a digital backbone across the control architecture, and IO-Link extended that richness to the simplest and most numerous devices in the plant.
The aim throughout has been to let operators monitor asset health, catch faults before they cause downtime, and swap devices without manual reconfiguration. In effect, this turns a one-way measurement signal into a foundation for predictive maintenance. In the next article, we will explore IO-Link in detail, covering its physical layer, data types, master-device architecture, and configuration and parameterization capabilities.
Featured image used courtesy of IO-Link.
