Google Expands TPU Lineup to 4, Each Targeting a Stage of Agentic AI
Google is boosting its eighth-generation TPU family to four systems in a year, with one confidential-computing variant of TPU 8t and a dual-chip TPU 8i package.
News 6 hours ago by Luke James
Google announced two new eighth-generation Tensor Processing Units (TPUs): TPU 8tx, which pairs TPU 8t training silicon with AMD EPYC host CPUs and hardware-enforced confidential computing, and TPU 8i Max, which puts two TPU 8i inference chips on one package to double per-socket compute and memory bandwidth. Both follow the TPU 8t and TPU 8i launched at Google Cloud Next in April, making this the first year Google has shipped four TPU systems.
The new TPU 8tx and TPU 8iMax.
Neither is a new chip, though, as both reuse silicon announced back in April with changes to the host CPU, packaging, and network fabric. That's why Google has been able to iterate so quickly and deliver them in months rather than the multi-year cycle of an entirely new die.
TPU 8tx
TPU 8tx uses the same silicon as TPU 8t, rated at 12.6 PFLOPS of native FP4 compute and 216 GB of HBM per chip. What's changed is the host. TPU 8t and TPU 8i run on Google's Arm-based Axion CPUs, while TPU 8tx runs on fifth-generation AMD EPYC, selected for its hardware enclave and attestation support.
The system targets data in use. Encryption covers data at rest and in transit, but a processor has to decrypt it in memory to work on it. TPU 8tx keeps model weights, prompts, and intermediate data isolated during that window. Futurum Group's Brendan Burke, reporting from Google's launch webcast, said the design enforces PCIe link encryption, cryptographic attestation, and secure memory enclaves across the TPU package and its EPYC host, with AMD Secure Encrypted Virtualization covering the CPU side. Google hasn't published an attestation audit or any third-party evaluation of the enclave.
TPU 8tx also adopts the Boardfly network topology Google built for TPU 8i, a hierarchical fabric that cuts maximum network diameter by more than 50% against the prior generation. Google claims up to twice the latency improvement over TPU 8t and near-zero performance cost from the security layer. Its intended customers are regulated enterprises and governments that want to fine-tune, distill, and run reinforcement learning on the same system that serves their models, without moving sensitive data between clusters. Google hasn't announced pricing, an availability date, or a launch customer yet.
TPU 8i Max
TPU 8i Max, meanwhile, addresses memory bandwidth, which runs out before compute when multiple agents work across a full codebase or hours of video at once. Google's answer to that is two TPU 8i chips on a single package.
A single TPU 8i carries 288 GB of HBM at 8.6 TB/s, 384 MB of on-chip SRAM, and 19.2 Tb/s of inter-chip interconnect bandwidth, while TPU 8i Max doubles compute, SRAM, and HBM bandwidth to 768 MB of SRAM and 17.2 TB/s per package. The two-chip package fits the existing TPU 8i rack footprint, meaning that operators get twice the silicon per square foot and per watt of rack allocation without changing the data center layout.
The evolution of Google's TPU family, each purpose-built for different stages of an agentic workload.
Google has been deliberate in making this doubling symmetric, holding that agentic inference is bound by the ratio of compute to memory bandwidth rather than either alone. Doubling only one side would shift the bottleneck rather than remove it, so TPU 8i Max doubles both and keeps the ratio where TPU 8i set it. The larger SRAM pool keeps more of a model's KV cache on-die during long-context decoding, the phase where processors most often stall on HBM.
The four systems now map to different stages of an agentic workload: TPU 8t for scale-up training, TPU 8i for low-latency reasoning, TPU 8tx for confidential execution, and TPU 8i Max for long-context work and rack density.
PyTorch Support and Memory Tiering
Google paired the hardware with a software push to run TPUs without hand-tuned code. TorchTPU, open-sourced in October, runs PyTorch code and Hugging Face models natively on TPUs, with backends for the vLLM and SGLang inference engines. TPU Sync, also being open-sourced, treats chip HBM, host DRAM, shared storage, and the data center network as one tiered memory hierarchy, spilling large KV caches off-chip and streaming context between disaggregated prefill and decode nodes. Google claims it cuts KV transfer latency and time to first token by more than 90%.
Google has also said that its TPUs now serve nearly 100 external customers and have shipped into third-party data centers since Q2 2026. However, Google has not yet published benchmarks for the new systems, and the AgentX figures it cited in its early November announcement were run on the seventh-generation TPU v7.
All images used courtesy of Google.
