Infineon Unwraps MCUs to ‘Set New Standard’ for Real-Time Control
The new PSOC Control C3 product line focuses on secure, high-performance power conversion and motor control applications.
Last week at Embedded World North America, Infineon announced a new family group of its PSOC microcontroller product line. The PSOC Control C3 Performance Line microcontroller family is designed for next generation power applications. Infineon is targeting the line precision control applications in AI power conversion, solar, EV charging, and high-end motor control.
The MCUs improve on speed and precision over prior PSOC models allowing for improved efficiency and more flexible operating parameters. The family includes PSOC Control C3 - PSC3P7xx, PSC3M7xx, PSC3P8xx, PSC3M8xx, in 48, 64, 80, and 100-pin packages.
At Infineon’s Embedded World North America booth last week, Infineon’s Marijana Vukisevic talks with All About Circuits’ Dale Wilson about the new PSOC Control C3 Performance Line MCUs.
The real-time processors start with an Arm Cortex M33 at 180MHz with included FPU and DSP. Zero wait-state analog and digital peripheral access and processing comes via a separate programmable power control accelerator (PPCA) running at 200 MHz. Real-time capability is further supplemented with a configurable logic block, events processing unit (EPU), and 3-Pole / 3-Zero digital compensator (3p3z filter).
According to the company, the MCU family is aimed at digital control applications that need higher switching frequencies while providing precision, security and maximum system efficiency.
Applications with Stringent Requirements
Power conversion in AI datacenters is a primary target application for the new microcontrollers. The latest AI datacenters are structured around high voltage DC facility power and require multiple DC-DC power conversion stages. New AI datacenter Power converters come with much more stringent requirements than legacy switch mode power supplies.
Supply efficiency requirements are reaching toward 97 to 99%. AI power delivery needs to contend with widely fluctuating demand. For example, the massively parallel processing utilized in AI often generates power load fluctuations of 50% loading up and down, repeatedly with millisecond pulsing. Such loading often requires silicon carbide (SiC) or gallium nitride (GaN) wide-bandgap (WBG) semiconductors.
The new PSOC processors allow higher switching frequencies – up to 2 MHz – and increased control loop bandwidth over prior models in the PSOC line making it optimal for high-power WBG semiconductors. Robotics, solar power converters and electric-power machinery also benefit from fast-responding microcontrollers for the same reasons.
Motor and Power Control Oriented Features
High precision control of motor and power devices requires fast feedback, the ability to rapidly perform control math, and quick response. Zero wait state processing goes a long way to fulfilling those requirements. The PSOC Control C3 Performance Line breaks out key functional areas to ensure minimal delays in important real-time functionality.
The PSOC Control C3 MCU block diagram on display at Infineon’s booth last week at Embedded World North America. (Click on image to enlarge)
Basic processing features are performed by a 180 MHz Cortex M33 CPU subsystem with hardware floating point (FPU) and digital signal processing (DSP) functional blocks. It is equipped with 128 KB of ECC SRAM, 16 KB I-cache, 512 KB ECC flash, and 64 KB ROM. The CPU subsystem also includes hardware security, DMA, 13 x 32 bit and 12 x 16 bit timer/counter/PWM controllers (TCPWM), DMA and up to 60 digital GPIO and up to 26 analog I/O.
The PPCA includes one or two dedicated Cortex M33 CPUs running at 200 MHz with 112 KB ECC SRAM, The PSC3x7xx models have one 200 MHz Cortex M33 in their PPCA while the PSC3x8xx have two. More information can be found in the PSOC Control C3 Performance Line data sheet.
Fast Peripherals and Advanced Math
High speed peripherals help the MCUs deliver better regulation and higher overall performance. The TCPWM supports <100 picosecond high resolution PWM and the nine differential comparator slope generators come with <10 ns latency. The four 12-bit successive approximation (SAR) ADC modules have parallel sampling of up to 24 channels with a speed of 25 Msps. Six of the ADCs support 64x oversampling for an effective 15-bit resolution.
The PSC3Mxxxx variants come with two additional power supply and motor control oriented hardware blocks: a coordinate rotation digital computer (CORDIC) specialized math co-processor, and a motion interface (MOTIF) block inside the TCPWM module. The CORDIC co-processor performs specialized advanced math functions used for high-precision motor control and power conversion. The MOTIF section sets timing and keeps track of the physical position of the motor’s rotor.
Security in an Insecure World
Security, and more specifically, post quantum security is a must for any connected microcontroller. Virtually all new high-performance electronics equipment is connected and thus a target for remote threats. The new PSOC family approaches this need with platform security architecture (PSA) L2 or L3 / EPC3
PSOC Control C3 Performance Line MCU. Image used courtesy of Infineon.
Infineon states that it has post quantum cryptography (PQC) support and is device identifier composition engine (DICE) ready. It also comes with SHA-512 and LMS firmware verification for secure boot, secure firmware update, code protection, secure attestation, secured key storage, authenticity, and integrity protection.
The PSOC Control C3 Performance Line is now available in sample quantities.
All images are All About Circuits images unless otherwise specified.
