Renesas’ New MPU Tackles HMI Challenges Head On With Built-In Memory
Tailored for advanced human-machine interfaces, the new RZ/A3M MPU can reduce system cost by integrating memory and simplifying PCB design.
News May 30, 2025 by Joshua Tidwell
From home appliances with vibrant touchscreens to factory panels streaming real-time data, human-machine interfaces (HMIs) have come a long way. But building these visually rich, interactive systems isn't cheap or simple. Developers often face a tangled web of memory requirements, real-time performance needs, and tight cost margins while trying to deliver a smooth user experience. That complexity slows development and increases risk, especially for manufacturers aiming to serve cost-sensitive markets.
RZ/A3M MPU
Renesas designed the RZ/A3M MPU for next-gen home appliances, healthcare devices, or even industrial or home automation.
Renesas says its newly launched RZ/A3M microprocessor unit (MPU) offers a way out. The RZ/A3M MPU integrates memory, processing, and graphics support into a compact package to meet the growing demand for high-performance HMIs in everything from industrial control panels to smart home devices.
MPUs Designed Specifically for HMI Applications
At the heart of the RZ/A3M (datasheet linked) is a 64-bit Arm Cortex-A55 core running at up to 1 GHz. That gives it the muscle to handle demanding graphics and multi-threaded tasks typical in modern HMIs. But where it really distinguishes itself is in its memory architecture. By embedding 128 MB of high-speed DDR3L SDRAM directly into the chip, the RZ/A3M eliminates the need for external memory in many use cases. This not only slashes board complexity and cost but also shortens development time by removing one of the more error-prone parts of embedded system design.
RZ/A3M’s block diagram
RZ/A3M’s block diagram. See page 9 of the datasheet for an enlarged image.
Renesas engineered the chip to support sharp, animated user interfaces on displays up to 1280 x 800 pixels. The RZ/A3M’s integrated 2D graphics engine and multiple display interfaces (including MIPI DSI and parallel RGB) enable smooth, visually engaging interfaces on applications from live video feeds on a building access panel to real-time analytics on a manufacturing dashboard. This makes it a strong fit for smart appliances, healthcare equipment, and even office automation systems.
What Does the RZ/A3M Offer?
The RZ/A3M provides a well-rounded suite of interfaces that qualify it as a complete HMI platform. From serial NAND/NOR flash support to USB 2.0, I2C, SPI, and audio interfaces, it’s designed to connect and control a wide range of peripherals. Developers can hook up touchscreens, sensors, audio outputs, and storage with little hassle.
The system’s footprint is also worth noting: its 244-pin BGA package with an outer-edge pin layout makes for straightforward PCB routing. That design simplifies production using a low-cost, dual-layer printed circuit board—a practical move for manufacturers trying to keep costs down without sacrificing function. Thermal sensors, timers, and a robust suite of communication channels round out the feature set, offering versatility across applications.
Renesas Provides Support and Development Tools
The RZ/A3M ships with support for a full RTOS-based environment and integrates easily into Renesas’ Flexible Software Package (FSP), which offers drivers, middleware, and sample projects. Developers don’t have to start from scratch—they can build on a tested foundation that’s designed to get products to market quickly.
Renesas’ HMI solution lineup
Renesas’ HMI solution lineup will feature evaluation kits and development tools to support its developers.
To accelerate HMI development specifically, Renesas has partnered with GUI software providers like LVGL, Crank, Envox, and SquareLine Studio. Their tools enable drag-and-drop interface design, animation support, and fast rendering—all optimized for the RZ/A3M’s hardware. Evaluation boards, reference designs, and “Winning Combinations” (pre-validated configurations with other Renesas components) further simplify design and reduce risk.
A Faster Path to Smarter Interfaces
The push for smarter, more responsive HMIs often hits a wall of cost and complexity. Renesas’ new RZ/A3M MPU directly tackles this challenge by integrating memory, offering powerful graphics support, and simplifying board design. With its strong feature set and robust development environment, the RZ/A3M may help developers build sophisticated interfaces faster.
All images used courtesy of Renesas.
