STMicroelectronics Releases USB PD Sink Controller With Hybrid Mode
The new USB Power Delivery sink controller combines hardwired USB-PD operation with a patented hybrid mode to simplify full-feature USB-C sink designs with minimal firmware.
News February 10, 2026 by Austin Futrell
STMicroelectronics recently released the STUSB4531 USB Power Delivery sink controller to reduce the firmware and validation complexity of USB PD. The device handles power negotiation internally and allows optional access to advanced USB-C features when required.
STUSB4531
The STUSB4531 combines hardwired USB Power Delivery operation with a hybrid mode that allows optional MCU interaction for advanced USB-C features.
The device may make it easier to add optional USB PD features to USB-powered and USB-chargeable designs in consumer, industrial, and embedded devices.
Key Features and Specifications
The STUSB4531 is a standalone USB Power Delivery sink controller that negotiates USB-C power using a certified, hardwired USB-PD stack. The standard charging operation does not require firmware. The controller supports USB-C 2.4, USB Power Delivery 3.2, and standard power-range profiles up to 100 W, along with adjustable-voltage supply profiles. It also enables dead-battery operation, promoting power negotiation before the system processor boots.
STUSB4531 diagram
The STUSB4531 sits between the USB-C connector, the battery charger, and the application processor to negotiate power and automatically manage VBUS.
The device monitors VBUS continuously. It adapts voltage supervision to the negotiated power profile and internally handles fault conditions. It also automatically manages restart behavior.
The STUSB4531 is available in QFN-16 (3 mm × 3 mm) and CSP-16 (2.3 mm × 2.3 mm) packages. The device targets USB-C sink ports in portable audio devices, wearables, printers, point-of-sale terminals, networking equipment, healthcare devices, industrial systems, and USB-powered lighting.
Why the Patented Hybrid Mode Matters
The STUSB4531 includes a patented hybrid mode. The device runs a complete USB-PD protocol stack internally. An external MCU can interact with selected protocol layers without implementing a full USB-PD stack.
Hybrid mode sits between fully hardwired and fully software-based designs. In hardwired mode, power negotiation and supervision operate autonomously. In hybrid mode, the STUSB4531 continues to manage protocol timing, message exchange, and compliance while notifying the MCU when advanced requests are required. The MCU can request features such as battery messaging, data role swapping, alternate modes, and vendor-defined messages. The STUSB4531 handles low-level protocol behavior. The MCU handles only high-level decisions.
This approach reduces firmware size and complexity. USB-PD timing constraints remain hardwired, and software development stays focused on application behavior rather than protocol implementation. Validation effort is reduced because protocol compliance remains internal to the controller.
Hybrid mode also keeps designs flexible. Advanced USB-C features can be added without redesigning the power architecture or rewriting a full USB-PD stack.
Autorun Enables Software-Free Power Management
Autorun mode allows the STUSB4531 to operate without firmware. The controller handles power negotiation automatically and selects the best available power profile from the source. VBUS is supervised continuously, and voltage monitoring follows the negotiated profile. Fault detection and recovery are handled internally.
Autorun mode remains active when the system processor is inactive. Dead-battery startup is supported, and power negotiation occurs before system boot. This eliminates the need for early USB-PD firmware and maintains consistent power behavior across chargers and adapters. Development time and validation effort are reduced as a result.
Development Tools and Availability
STMicroelectronics provides evaluation boards and reference designs for the STUSB4531. It also offers configuration tools and NVM programming utilities. A planned open-source software library will support hybrid-mode development. The STUSB4531 is in production now, with pricing starting at approximately $1.17 per 1,000 units. The device is intended for USB-C sink designs that require fast charging, optional data support, and minimal firmware.
All images used courtesy of STMicroelectronics.
