ST’s New High-Precision Op Amp Takes Aim at the 4 V to 36 V Range
The dual operational amplifier offers 20-µV precision across a wide 36-V supply range, eliminating the need for complex compensation in industrial and automotive signal chains.
STMicroelectronics has announced the new TSB192 dual operational amplifier, delivering high-precision performance across a wide 4-V to 36-V operating range. These new components address the historical challenge of choosing between high-voltage capability and sub-50 µV offset voltages, often necessitating complex level-shifting circuitry in 24-V industrial or automotive systems.
The TSB192 comes in SO-8 and MiniSO-8 packages. Image used courtesy of STMicroelectronics
According to the company, by delivering a maximum offset of 20 µV directly on higher-voltage rails, the TSB192 simplifies signal-conditioning networks and eliminates the need for additional power-management stages.
ST’s TSB192 Dual-Operational Amplifier
Engineers can use the TSB192 to achieve a maximum input offset voltage of 20 µV at 25°C, providing a high-speed alternative to the TSB182 with an 8-MHz gain-bandwidth product. To maintain this accuracy, the internal architecture limits temperature drift to 100 nV/°C while providing a 5-V/µs slew rate for fast signal reproduction. Designers can rely on an equivalent input noise voltage of 11 nV/√Hz to preserve signal integrity in noise-sensitive measurement circuitry, such as electronic scales and medical instrumentation.
Pin connections on the TSB192 package. Image used courtesy of STMicroelectronics
Because each channel consumes up to 2.2 mA over the full -40°C to 125°C temperature range, engineers can effectively extend the runtime of battery-operated equipment without sacrificing performance. According to ST, the TSB192's power efficiency, combined with rail-to-rail outputs, maximizes the available dynamic range in signal-conditioning stages.
The device includes ESD tolerance up to 4 kV Human Body Model and is available in SO-8 or MiniSO-8 packages to enable smaller PCB footprints and reduced system costs.
Input Offset Voltage Drift in Precision Amplifiers
Input offset voltage represents the differential DC voltage required at the inputs of an operational amplifier to force the output to zero. While a low initial offset is vital for accuracy, offset voltage drift describes how it changes with ambient temperature. In precision measurement, this drift is often the dominant source of error because it cannot be easily calibrated out at the time of manufacture.
Temperature drift occurs due to internal mismatches between components in the amplifier’s input stage, such as transistors and resistors. As the temperature shifts, the physical properties of these silicon structures change at slightly different rates, typically quantified in nanovolts or microvolts per degree Celsius (nV/°C or µV/°C). Small drift can cause significant measurement errors in high-gain configurations where the error is multiplied at the output.
Block diagram of a chopper-stabilized zero-drift op amp. Image used courtesy of IEEE Xplore
Therefore, minimizing drift is essential in applications such as strain gauge bridges and thermocouple interfaces, as the signal of interest is very small. Engineers should prioritize zero-drift or low-drift architectures to guarantee a system's precision remains consistent from a cold start to its maximum operating temperature.
A Solution for High-Voltage Signal Chains
STMicroelectronics has placed the TSB192 into production in SO-8 and MiniSO-8 packages. While the current version supports industrial and automotive temperature ranges, a dedicated automotive-grade version is scheduled for release later in 2026.
