A Tiny Synchronous Step-Down DC-DC Converter With 5 V, 600mA Output
This project brief presents a buck module that converts 4 V to 36 V input to a 5 V output on a compact PCB. It uses a TPS560430 synchronous step-down DC-DC converter.
This compact buck converter delivers a regulated 5 V DC output at up to 600 mA. It accepts a wide input range of 4 V to 36 V DC. That makes it well suited to industrial, automotive, and general-purpose designs that run from unregulated power sources. Figure 1 shows the assembled module.
Figure 1. The assembled Tiny Synchronous Step-Down DC-DC Converter
module.
Figure 1. The assembled Tiny Synchronous Step-Down DC-DC Converter module.
The design is built around the Texas Instruments TPS560430XF synchronous step-down converter in a SOT-23-6 package. Internal soft-start and compensation keep the external parts count low, so the whole circuit fits on a 14.45 mm × 11.43 mm PCB.
A single 3-pin header carries the input, ground, and 5 V output. The board can plug directly into a breadboard or a host PCB, much like a three-terminal linear regulator.
Specs and Features
  • Input voltage: 4 V to 36 V DC
  • Output voltage: 5 V DC
  • Output current: 400 mA continuous (600 mA maximum)
  • Switching frequency: 1.1 MHz, forced PWM (FPWM) operation
  • Minimum switch on-time: 60 ns
  • Maximum duty cycle: 98%
  • Protection: cycle-by-cycle current limit, hiccup-mode short-circuit protection, and thermal shutdown
  • 3-pin header (2.54 mm pitch) for input and output power
  • PCB dimensions: 14.45 mm × 11.43 mm
How It Works
Figure 2. Functional block diagram of the TPS560430. Image used
courtesy of Texas Instruments.
Figure 2. Functional block diagram of the TPS560430. Image used courtesy of Texas Instruments.
The TPS560430 integrates both the high-side and low-side power MOSFETs. Synchronous rectification replaces the catch diode found in a conventional buck converter, which improves efficiency. The functional block diagram is shown in Figure 2.
The XF version used here switches at a fixed 1.1 MHz in forced PWM mode. FPWM holds the switching frequency constant across the full load range. This keeps output voltage ripple low, even at light loads.
A resistor divider (R1 and R3) sets the output voltage. The 1 V internal reference and the 88.7 kΩ/22.1 kΩ divider set the output to 5 V. R2 pulls the enable pin up to the input, so the converter starts as soon as power is applied. C1 is the 100 nF bootstrap capacitor that drives the high-side MOSFET gate.
Although the converter can supply up to 600 mA, continuous operation at full load is not recommended. The compact PCB has limited copper area for dissipating heat.
Schematic and Bill of Materials
The complete schematic is shown in Figure 3. D1, R4, and C4 are optional footprints and are not populated.
Figure 3. Schematic of the Tiny Synchronous Step-Down DC-DC
Converter.
Figure 3. Schematic of the Tiny Synchronous Step-Down DC-DC Converter.
The bill of materials is shown in Table 1.
Table 1. BOM for Tiny Synchronous Step-Down DC-DC Converter.
REF DESCRIPTION QTY MFG SUPPLIER PART NO.
CN1 3-pin male header, 2.54 mm pitch 1 Würth DigiKey 732-5316-ND
C1 100 nF/50 V ceramic, SMD 0805 1 Yageo/Murata DigiKey
C2 22 µF/16 V ceramic, SMD 0805 1 Yageo/Murata DigiKey
C3 10 µF/50 V ceramic, SMD 0805 1 Yageo/Murata DigiKey
D1, R4, C4 DNP 3
L1 15 µH, 1.5 A (5 × 5 mm) 1 Bourns DigiKey SRP4020TA-150MCT-ND
R1 88.7 kΩ 1%, SMD 0805 1 Yageo/Murata DigiKey
R2 100 kΩ 5%, SMD 0805 1 Yageo/Murata DigiKey
R3 22.1 kΩ 1 Yageo/Murata DigiKey
U1 TPS560430XF 1 TI DigiKey 296-52607-1-ND
Connections
The connection diagram is shown in Figure 4.
Figure 4. Connection diagram for the Tiny Synchronous Step-Down DC-DC
Converter.
Figure 4. Connection diagram for the Tiny Synchronous Step-Down DC-DC Converter.
CN1 — Power Header (3-pin, 2.54 mm pitch):
  • Pin 1 = Power Input, 4 V to 36 V DC
  • Pin 2 = GND
  • Pin 3 = 5 V DC Output
PCB Files
The PCB layout is shown in Figure 5. The design is 14.45 mm × 11.43 mm.
Figure 5. PCB layout of the Tiny Synchronous Step-Down DC-DC
Converter.
Figure 5. PCB layout of the Tiny Synchronous Step-Down DC-DC Converter.
You can download the layout files for this project here:
Tiny Step-Down DC-DC Converter
Except where noted, all images used courtesy of Rajkumar Sharma
