Discrete Semiconductor Devices and Circuits
Active Loads in Amplifier Circuits
7 questions By Tony R. Kuphaldt
Page 1 of 3 0 of 7 answers revealed (0%)
  • Question 1 of 7
    We know that the current in a series circuit may be calculated with this formula:
    $$I=\frac{E_{total}}{R_{total}}$$
    We also know that the voltage dropped across any single resistor in a series circuit may be calculated with this formula:
    $$E_R=IR$$
    Combine these two formulae into one, in such a way that the I variable is eliminated, leaving only ER expressed in terms of Etotal, Rtotal, and R.
    Reveal answer
  • Question 2 of 7
    Determine what will happen to the output voltage (Vout) and resistor R1‘s current (IR1) in this circuit as the resistance of R2 is increased:
    Reveal answer
  • Question 3 of 7
    Suppose we were to compare the performance of two voltage divider circuits side-by-side. The circuit on the left has one variable resistor (R2), while the circuit on the right has two variable resistors (R1 and R2). The right-hand circuit’s resistors are ganged together in such a way that as one resistance increases, the other will decrease by the same amount, keeping the circuit’s total resistance constant:
    Knowing that the voltage output by a voltage divider is described by the following formula, determine which voltage divider circuit yields the greatest change in output voltage for a given change in R2‘s resistance.
    $$V_{out}=V_{battery}(\frac{R_2}{R_1+R_2})$$
    Reveal answer
Worksheets
AAC Worksheets
