Digital Circuits
Binary Math Circuits
11 questions By Tony R. Kuphaldt
Page 1 of 4 0 of 11 answers revealed (0%)
  • Question 1 of 11
    Add the following binary numbers:
    Reveal answer
  • Question 2 of 11
    Don’t just sit there! Build something!!
    Learning to analyze digital circuits requires much study and practice. Typically, students practice by working through lots of sample problems and checking their answers against those provided by the textbook or the instructor. While this is good, there is a much better way.
    1. Draw the schematic diagram for the digital circuit to be analyzed.
    2. Carefully build this circuit on a breadboard or other convenient medium.
    3. Check the accuracy of the circuit’s construction, following each wire to each connection point, and verifying these elements one-by-one on the diagram.
    4. Analyze the circuit, determining all output logic states for given input conditions.
    5. Carefully measure those logic states, to verify the accuracy of your analysis.
    6. If there are any errors, carefully check your circuit’s construction against the diagram, then carefully re-analyze the circuit and re-measure.
    Always be sure that the power supply voltage levels are within specification for the logic circuits you plan to use. If TTL, the power supply must be a 5-volt regulated supply, adjusted to a value as close to 5.0 volts DC as possible.
    Reveal answer
  • Question 3 of 11
    Identify each of these logic gates by name, and complete their respective truth tables:
    Reveal answer
