Don’t just sit there! Build something!! |
Avoid very high and very low resistor values, to avoid measurement errors caused by meter “loading”. I recommend resistors between 1 kΩ and 100 kΩ, unless, of course, the purpose of the circuit is to illustrate the effects of meter loading!
Let the electrons themselves give you the answers to your own “practice problems”!
Convert all the “Thévenin” sources into Norton equivalent sources in this network:
Simplify this circuit by combining all Norton sources into one, then solve for the voltage between the two busses:
This is a good review of current sources and parallel resistances.
Write an algebraic equation that solves for the voltage between the two bus conductors, based on the problem-solving method of Thévenin-to-Norton conversion, combining Norton sources into one, and combining resistors into one:
At first it may seem a bit overwhelming to derive an equation from these steps, but it is actually easier than it looks. A hint on how to do it: begin with the last step of the circuit simplification process, and work backwards as you elaborate your equation.
Calculate the voltage indicated by the voltmeter in this circuit for the following voltage inputs:
What do you notice about the output voltage of this circuit? What mathematical function does this circuit perform?
Vout = 7.0 volts
This circuit is a very simple form of analog computer, because it has the ability to perform a mathematical operation, with voltages representing numerical quantities!
Not only does this simple circuit provide an excellent opportunity to practice using Millman’s theorem, but it also illustrates the important principle of using resistor networks to perform mathematical functions. In essence, this circuit is a form of computer (an analog computer), capable of “calculating” at a rate of speed unmatched by any digital computer.
Ask your students to think of the advantages an analog computer such as this would have over a digital computer, and visa-versa. How come analog computers are seldom used, and digital technology is so prevalent? Does this mean analog computer technology has no place in modern electronics?
Suppose this circuit was found to output a voltage of 11.0 volts, given the input voltages shown:
What do suspect is wrong with this circuit? How would you verify the cause of the incorrect output voltage?
The upper resistor is failed open.
Note how even with a failed resistor, the circuit still performs the proper mathematical function (albeit, only regarding two of the input “channels” rather than three). Ask your students how they determined the source of the problem, and how they would verify that as being the fault, with just a single meter measurement.
What would a digital voltmeter register, if connected to the circuit as shown below?
If you calculated 3.797 volts, you made a mistake! In actuality, the voltmeter would register 1.235 volts.
A very common mistake I’ve seen students make is to disregard polarities when using Millman’s theorem. If this appears to be a common problem in your class, ask your students if they think reversing one of the voltage source polarities would have any effect on the “bus” voltage. Of course, it should. Once students understand that polarity is significant, they can arrive at their own consistent approach to accounting for polarity in the Millman’s theorem equation.
Another strategy for getting students to understand the significance of polarity when using Millman’s theorem is to go back to the foundations of Millman’s theorem: the principle of converting Thévenin sources into Norton sources. If a Thévenin source with a “backwards” battery is converted into a Norton source, that current source will subtract current from the rest of the current sources, leaving less to go through the total Norton resistance. Students should be able to readily understand the principle of Norton current sources adding versus subtracting, and this should then carry over into their use of the Millman’s theorem equation.
A set of batteries are connected in parallel to form a battery bank. Ideally, their individual voltages would be exactly equal, and there would be no stray resistance anywhere in the circuit, but in reality what we have is something like this:
Use Millman’s theorem to calculate the total voltage between the two busses for the battery bank, given these specifications for the four batteries:
Bus voltage = 12.051 V
Millman’s theorem is especially useful in making bus voltage calculations for power systems, where multiple sources (and loads!) are connected to the same two wires.
Calculate the voltage across the starter motor terminals of the “dead” car, and the current through the starter motor, while a second car is giving it a jump-start:
Regard the starter motor itself as a 0.15 Ω resistor, and disregard any resistance of the jumper cables connecting the two cars’ electrical systems together.
Emotor = 9.534 V
Imotor = 63.56 A
For a question like this, where an equivalent schematic diagram is essential to obtaining the solution, I recommend you have a student draw their equivalent schematic on the whiteboard in front of the class, and discuss the diagram with all your students before discussing how to apply Millman’s theorem.
I have found it helpful for students to have them draw diagrams and mathematical solutions on a board in front of the rest of the class. Of course, you as the instructor must be careful to maintain a non-threatening environment in the classroom while students do this, as it tends to place a lot of stress on shy students. However, the ability to present graphical information to a group is a valuable skill, and exercises like this help to build it in your students.
by Luke James
In Partnership with Siemens Digital Industries Software
by Steve Arar
by Luke James
by Luke James
