Semiconductor System Offering Enabling Combustion to Electric Transition in Power Tools
Environmentally conscious companies and governments no longer want to use combustion engines in power tools and support the change to electrical ones.
Environmentally conscious companies and governments no longer want to use combustion engines in power tools and support the change to electrical ones. Infineon tackles the resulting design challenges with a semiconductor system offering for related applications. We show you what needs to be considered in designs to enable this transition.
Key Takeaways
- Identify design challenges in higher power/ voltage cordless power tools
- Discover suitable Infineon components and system solutions
- Learn what is critical when turning your designs into electrical ones
This webinar will be a perfect fit if one of the following applies to your profession:
Applications: Cordless power/garden tools, BLDC motors
Industry: Electrical home appliances
Technologies: LV / MV motor control, motor drive, connectivity, LV / MV charging, Li-ion batteries, BMS, security
Get yourself ready for the session with Hrach and Adam:
Browse our offering for battery-powered DC motor power tools. Click here.
Get to know the newly launched 3-phase fully-programmable motor control gate driver IC for battery-supplied BLDC motor control. Click here.
Infineon's OptiMOS™ 5 150V - breakthrough reduction in RDS(on) and Qrr. Learn more.
