EPCOS Power Line Chokes | Tech Specs
Normally, choking is bad, but as is typically the case with RF and EMI, the opposite is true; chokes are essential to many electronic devices, as they suppress common mode noise.
New Product February 22, 2018 by TTI, Inc
Normally, choking is bad, but as is typically the case with RF and EMI, the opposite is true; chokes are essential to many electronic devices, as they suppress common mode noise. EPCOS offers a wide range of current-compensated power line chokes using a closed core topology to address all your common-mode filtering needs. Chokes range from compact, low current models to larger models capable of handling up to 62 amps. Voltage ratings range from 250 to 1000 volts AC, and chokes are available with two to four lines to address different supplies. Many are available with UL and VDE approvals and horizontal or vertical mounting. So, whether your application is a small device with a switch mode power supply, an electronic ballast, or a large power inverter, EPCOS power line chokes are available to meet your needs.
  • Current-compensated ring core chokes
  • Current ratings up to 62 A
  • Voltage ratings from 250 VAC to 1000 VAC
  • Two, three, and four line models
  • UL, VDE approvals on many models
  • Horizontal and vertical mounting options
More Information
