Cadence Races First to Release LPDDR6/5X Memory IP for AI Infrastructure
The new solution arrives in tandem with JEDEC’s LPDDR6 standard to provide higher bandwidth and efficiency for AI workloads.
News July 17, 2025 by Jake Hertz
Cadence recently announced the tapeout of its LPDDR6/5X memory IP system solution, the industry’s first to support data rates of up to 14.4 Gbps.
LPDDR6/5X IP
Designed for AI applications, the new LPDDR6/5X IP is a high-speed architecture based on Cadence’s LPDDR5X 10.7 Gbps and GDDR6 22 Gbps products.
This development coincides with JEDEC's official release of the JESD209-6 LPDDR6 standard. As such, the new solution is set to accommodate the rising computational and memory bandwidth demands of next-generation AI models.
Architectural Design of the LPDDR6/5X Memory IP
Cadence’s LPDDR6/5X memory IP system integrates a fully-compliant PHY and controller architecture that operates at 14.4 Gbps, which is approximately 50% faster than previous LPDDR5X solutions. The PHY architecture is derived from Cadence’s earlier GDDR6 and LPDDR5X platforms but offers specific enhancements such as dynamic feedback equalization (DFE), feed-forward equalization (FFE), and continuous-time linear equalization (CTLE) to maintain signal integrity at high speeds. Cadence claims that per-bit read and write delay adjustments, along with fine-grain delay tuning, unlock powerful timing calibration across variable system conditions.
A solution example using the Cadence LPDDR6/5x
A solution example using the Cadence LPDDR6/5x.
To support scalability and design flexibility, the IP system offers hardened PHY macros for multiple floorplans, bump map configurations, and soft RTL macros for the controller. Cadence claims that this modularity supports both monolithic SoC designs and chiplet-based architectures through Cadence’s UCIe-based framework. On the logic level, low-frequency, top-level clocks simplify timing closure in complex digital designs.
Low-power features are also a central element of the system’s design. For example, the controller supports multiple dynamic frequency scaling (DFS) modes and low-power states such as VDD idle and VDD light sleep. Integrated reliability features include parity checking, error correction code (ECC), and scrubbing support. Additionally, the solution comes with a comprehensive LPDDR6 memory model for verification, which provides protocol checks and functional coverage to speed integration into SoCs.
A Dual Sub-Channel Architecture and Efficiency Features
One of the most notable features of the LPDDR6 standard is its dual sub-channel architecture. This feature optimizes access efficiency and reduces access granularity for high-performance AI workloads.
Each DRAM die contains two independent 12-bit sub-channels, effectively doubling the access paths while maintaining a small granularity of 32 bytes. Each sub-channel includes four dedicated command/address (CA) lines for precise, concurrent transactions and reduced contention within memory banks. This architecture is specifically designed to reduce latency and improve throughput when servicing the irregular, high-frequency access patterns found in AI inference models and edge workloads.
By separating the memory interface into two independently operable sub-channels, LPDDR6 allows parallel read and write transactions to different memory regions. This helps minimize idle cycles and data hazards, which are common when working with small, non-contiguous data blocks typical of transformer-based AI models. Furthermore, LPDDR6 includes on-the-fly burst length switching between 32 B and 64 B, permitting dynamic tuning of data transfer sizes without requiring a configuration change.
An eye diagram for an LPDDR6 memory interface
LPDDR5X hardware operating at LPDDR6 speed
To address the power-performance tradeoff, LPDDR6 introduces both static and dynamic efficiency modes. Static efficiency mode is optimized for high-capacity memory configurations and allows the controller to exploit full DRAM resources efficiently under sustained, high-throughput conditions. By contrast, dynamic efficiency mode is tailored for low-bandwidth operations such as background tasks or sensor data handling in edge devices. Designed to be entered and exited with minimal latency, this mode restricts activity to a single sub-channel, reducing internal switching power and peripheral activation energy.
Signal integrity and adaptive termination are further enhanced in LPDDR6 through dynamic write NT-ODT (non-target on-die termination). This mechanism adjusts termination impedance dynamically depending on the direction and load of the transaction. For instance, when multiple dies or ranks are present on the same memory channel, NT-ODT allows only the non-target devices to activate termination resistance, reducing reflections and crosstalk.
Expanding Memory Design in AI Systems
As the first company to roll out memory IP alongside the newly ratified JESD209-6 LPDDR6 standard, Cadence hopes its LPDDR6/5X offering will position the company as a leader in memory interface solutions. The solution is available now for customer engagement.
All images used courtesy of Cadence.
