EDA Companies Throw Support Behind TSMC’s New A14 Process
TSMC’s new A14 process is already backed by certified EDA tools from Cadence, Synopsys, and Siemens to accelerate next-gen AI and chiplet-based designs.
At its recent North America Technology Symposium, TSMC unveiled its next-generation A14 process technology—an ambitious leap beyond the soon-to-be-deployed N2 node. Hot on the heels of this announcement, several EDA companies publicly declared support for the A14 platform, aligning their tools and flows with the foundry’s future-facing roadmap.
TSMC will launch A14 production in 2028. Image used courtesy of TSMC
A14 Ushers in the Angstrom Era
Expected to enter production in 2028, A14 builds on the nanosheet foundation laid by the N2 process. The upgrade delivers up to 15% speed improvement or 30% power reduction at equivalent performance, along with a 20% logic density boost. TSMC has also introduced its NanoFlex Pro standard cell architecture, enhancing design flexibility and pushing the limits of AI acceleration, mobile computing, and edge innovation.
| Features | A14 (1.4 nm) |
| Production Date | 2028 |
| Transistor Architecture | Gen 2 GAAFET, Nanoflex Pro |
| Performance | +15% than N2 |
| Power Consumption | -30% than N2 |
| Logic Density | +20% than N2 |
| Packaging | Larger-scale integration than N2 |
Beyond the transistor, TSMC’s roadmap broadens to advanced packaging with chip-on-wafer-on-substrate (CoWoS), its compact universal photonic engine (COUPE), and high-bandwidth memory support. These additions are not peripheral; they’re foundational to realizing the chiplet-based, multi-die architectures that define AI-era compute platforms.
Cadence, Synopsys, and Siemens Back the Process
Cadence, Synopsys, and Siemens are among the early adopters certifying tools for A14 while extending robust support across existing platforms like A16, N2P, and 3DFabric.
Cadence’s collaboration with TSMC now spans digital, analog, and thermal analysis tools certified for both N2P and A16. The company's A14 work is already underway, building on pre-silicon DDR5 IP, UCIe-compatible chiplet interfaces, and 3Dblox-enabled 3DIC flows. Cadence is also advancing CoWoS-L support, tailored for AI workloads with HBM3E integration and feedthrough-aware planning.
TSMC leverages CoWoS for heterogeneous integration, pictured above. Image used courtesy of Cadence
Meanwhile, Synopsys brings to the table Synopsys.ai-driven design flows, a broad IP catalog, and early A14 enablement. From PCIe 7.0 to 1.6T Ethernet, Synopsys' certified IP portfolio positions it as a turnkey provider for AI and high-speed SoCs. Collaboration on CoWoS and 3Dblox further cements its role in TSMC’s heterogeneous computing push.
Siemens, too, reinforces its alliance with certified analog, DRC/LVS, power integrity, and 3D packaging tools. Its Calibre and AFS platforms are now qualified across A16 and N2P, while its 3DSTACK and Solido Design Environment tools are actively contributing to TSMC’s COUPE and photonic design efforts.
An Established Development Model
TSMC’s collaboration with EDA vendors has been a consistent element of its process node development strategy. From N7 to N5 to N3, each new node has involved formal certification of EDA tool flows to ensure compatibility with TSMC’s design rules and manufacturing requirements. These certifications cover key areas such as physical verification, layout automation, timing analysis, power integrity, and thermal modeling. As nodes become more complex, the integration between process technology and design tools becomes increasingly critical to enable first-pass silicon success.
The positive impact of EDA tool readiness is apparent in downstream development in AI, hyperscale, mobile, automotive, and IoT. In AI applications, high-performance SoCs increasingly rely on 3D integration, HBM memory, and large chiplet arrays. These require close coordination between physical design tools and packaging platforms like CoWoS and 3DFabric.
In automotive, process nodes like N3A and N5A, certified by vendors like Cadence and Siemens, support advanced driver assistance systems and software-defined vehicle architectures. For mobile and edge AI, improvements in power efficiency at A14 are expected to support always-on inferencing and enhanced local processing.
With several EDA vendors already engaged, A14 is entering the ecosystem with broad tool support. Certification at this stage enables early silicon design and provides a foundation for subsequent IP development and physical verification.
