Insight SIP Expands Popular Line of BLE Modules With New Variants
Insight SiP adds LL, LX, and LP variants to its ISP2454 BLE series, offering different power and memory configurations to meet varied IoT design needs.
News January 27, 2026 by Joshua Tidwell
Insight SiP has expanded its ISP2454 series with three Bluetooth Low Energy modules: the ISP2454-LL, ISP2454-LX, and ISP2454-LP.
ISP2454
All three modules (datasheet linked) share an 8 mm × 8 mm × 1 mm LGA footprint and are based on Nordic Semiconductor’s nRF54L15, with the only real differences limited to timing crystal configuration and available memory.
Core Architecture of the ISP2454‑LX
The ISP2454-LX is the standard configuration in the series, built around an Arm Cortex-M33 processor running at 128 MHz, with 1.5 MB of non-volatile RAM and 256 KB of RAM. The module includes both a 32-MHz system crystal and a 32-kHz low-power crystal, supporting accurate timing and low-power sleep operation.
ISP2454
Block diagram of the ISP2454.
The ISP2454-LX module features an integrated RF matching network and supports Bluetooth 6.0, Bluetooth Mesh, Thread, Matter, NFC-A, and proprietary 2.4-GHz protocols. It is designed as a compact wireless module for battery-powered applications that need multi-protocol support.
Variant Details
The ISP2454-LL is the simplest version in the family and includes the main 32-MHz system crystal but omits the 32-kHz, low-power crystal, making it a better fit for mains-powered equipment or designs where Bluetooth power draw isn’t a top concern. Aside from that, it uses the same processor, memory, and radio as the other variants, so performance stays consistent while the overall design and cost stay simpler.
The ISP2454-LX is the fully integrated option and the version that’s already in production. With both timing crystals onboard, it supports the full low-power feature set of the nRF54L15. That makes it a solid choice for battery-powered products such as sensors, wearables, and smart home devices, especially when long battery life and support for multiple wireless protocols are required.
The ISP2454-LP builds on the LX by adding 4 MB of external flash memory, providing extra storage to accommodate larger firmware images, including Matter-based applications. It also supports dual-image, over-the-air updates with rollback. It suits devices that need to store data locally for extended periods, such as remote monitoring or environmental sensing applications.
Compatibility and Development Tools
All three variants of the ISP2454 series are pin‑compatible with one another and with Insight SiP’s earlier ISP1507, ISP1807, and ISP1907 modules, allowing manufacturers to upgrade existing designs to the nRF54L15 platform without altering PCB layouts. Insight SiP also provides evaluation boards and test boards with integrated debugging hardware, NFC antennas, and full I/O access to support firmware development and RF testing.
ISP2454-LX-EB (left) evaluation board and ISP2454-LX-TB
ISP2454-LX-EB (left) evaluation board and ISP2454-LX-TB (right) test board.
Insight SIP’s expanded ISP2454 lineup provides developers with a hardware platform with multiple configurations tailored to different power and memory requirements. By basing the series on the nRF54L15 and maintaining a unified footprint, Insight SiP provides a straightforward path for building or upgrading IoT devices across a wide range of applications.
All images used courtesy of Insight SIP.
