Keysight Fits a Full-Featured, 14-Bit Oscilloscope Into a One-Rack Unit
The InfiniiVision XR3 puts four analog and 16 digital channels in a rack-mount chassis that designers can synchronize with other units.
News 31 minutes ago by Jake Hertz
Keysight has introduced the InfiniiVision XR3, a 14-bit oscilloscope housed in a 1U rack-mount chassis.  As designers assemble test systems with more channels, they face a tradeoff between measurement performance and rack space. As a result, they need oscilloscopes that stack densely, share a common timebase, and maintain benchtop-level resolution.
The InfiniiVision XR3 fits a four-channel, 14-bit oscilloscope into a 1U rack-mount chassis. Image (modified) used courtesy of Keysight Technologies
Keysight designed the XR3 to support synchronized measurements across hundreds of channels while preserving high-resolution signal acquisition.
Rack-based test systems show how much space a conventional oscilloscope's display and front panel consume. When designers need dozens of channels, those benchtop instruments and their cabling quickly fill a cabinet. To address that limit, Keysight designed the XR3 as a 1U rack-mount instrument. According to the company, the XR3 delivers four-channel, mixed-signal measurement in a smaller, lighter package than benchtop scopes, with less cabling.
Despite the low profile, Keysight places the XR3 in the same oscilloscope class as its HD3 benchtop series. The company designed the XR3 around its MegaZoom 5 custom ASIC and a 14-bit analog-to-digital converter (ADC). The XR3L4A offers bandwidth options from 200 MHz to 1 GHz, a maximum sample rate of 3.2 GSa/s, and 100 Mpts of acquisition memory. Keysight lists a 50-µVrms noise floor and says the 14-bit ADC provides four times the vertical resolution of a 12-bit ADC.
Beyond resolution, Keysight focused on how quickly the XR3 refreshes waveforms. According to the company, the scope updates at 1.3 million waveforms per second, which improves the odds of catching infrequent glitches. Keysight's MegaZoom 5 ASIC handles real-time zoom, filtering, zone triggering, and waveform color grading in hardware, helping preserve high waveform update rates. For analysis, Keysight includes native protocol decode, power supply test, and jitter analysis software.
Digital trigger allowing the XR3 to trigger and display a 100 µV sine wave
Digital trigger allowing the XR3 to trigger and display a 100-µV sine wave. Image used courtesy of Keysight Technologies
To scale past four analog channels, designers can link multiple XR3 units. Each XR3 provides an autosensing 10-MHz reference input and output, allowing multiple instruments to share a common timing reference. The company also handles synchronization, unit discovery, and deskew in hardware, which simplifies setup. According to Keysight, designers can combine units into one system with more than 100 time-correlated channels.
To manage that system, engineers can run Keysight's Infiniium 2026 software on an external computer and control several XR3 units from one screen. Designers can also pair the XR3 with Keysight's XR8 oscilloscope to add low-noise, high-impedance (Hi-Z) channels without an adapter.
Keysight targets the XR3 at aerospace and defense, manufacturing, and physics test systems. In those settings, engineers may need to capture many signals on one timebase within a fixed rack footprint. A production tester, for example, could fit more channels per station, while a physics experiment could time-align diagnostics from many sensors.
Keeping Many Channels on One Timebase
One long-standing challenge in high-channel-count testing is keeping every channel on the same time reference. Each standalone instrument normally samples from its own internal oscillator. Because no two oscillators run at exactly the same frequency, their sample clocks drift apart over time. For that reason, engineers commonly distribute a shared 10-MHz reference so every instrument locks to one source.
However, a shared reference alone does not align the samples. As Analog Devices explains, trace lengths, connectors, and backplanes add skew between the clock and synchronization signals at each converter. Signals that cross clock domains inside each device add further latency variation.
Example of a JESD204B multi-ADC system
Example of a JESD204B multi-ADC system distributing clock and synchronization signals to two ADCs and an FPGA. This is not an XR3 architecture diagram. Image used courtesy of Analog Devices
To compensate for timing skew, engineers can characterize signal-path delays and align the resulting samples through appropriate timing adjustments or digital processing. At the instrument level, the same principle applies to trigger cables and front-end paths between units. If engineers leave that skew uncorrected, they see timing errors between channels that distort edge and phase comparisons.
Scaling Oscilloscope Channels in the Rack
For engineers building high-channel-count test systems, the XR3 combines high-resolution acquisition with hardware-assisted synchronization in a compact rack-mount format. Keysight lists the XR3L4A on its product page, where customers can request pricing and explore bandwidth, system, and software upgrades.
