Siglent Expands High-Speed Test Portfolio With New Probe & VSA Software
The new 8-GHz active differential probe and vector signal analysis software target PCIe, DDR, USB, Ethernet, Wi-Fi, LTE, and 5G signal analysis.
Siglent recently introduced two new products for high-speed digital and RF testing. The products include the SAP8000D active differential probe and the SigVSA vector signal analysis software. The probe is designed to improve measurement accuracy during high-frequency testing, while SigVSA provides signal analysis tools for PCs and supported Siglent oscilloscopes and spectrum analyzers.
The SAP8000D active differential probe and SigVSA software target high-speed digital, RF, and wireless communication testing.
The SAP8000D probe and SigVSA software tackle different stages of the test workflow. The probe is designed to preserve signal integrity during high-speed measurements, while the SigVSA software provides analysis and decoding tools for a wide range of wireless and digital communication standards, from basic modulation schemes to LTE and 5G.
Capturing High-Speed Signals Without Disturbing Them
Siglent built the SAP8000D active differential probe for high-speed measurements, where the probe itself can influence the results. The probe offers 8-GHz bandwidth and an ultra-low, 300-fF input capacitance, helping reduce loading on sensitive circuits so engineers can capture cleaner, more accurate waveforms. Lower input capacitance also helps preserve fast signal edges, making it easier to evaluate signal integrity during debugging and validation.
Siglent's SAP8000D supports high-speed signal validation with 8-GHz bandwidth, low input capacitance, and multiple probing options.
The probe supports both differential and single-ended measurements and provides high common-mode rejection for improved performance in electrically noisy environments. It's intended for applications such as signal integrity analysis, RF circuit debugging, and validation of high-speed interfaces including PCIe, DDR, USB 3.0, and Gigabit Ethernet.
The SAP8000D also supports multiple probing methods, including solder-in, handheld, and fixture-based connections. That flexibility, combined with a range of available accessories, streamlines workflows that involve prototype boards, production hardware, or tightly packed PCB layouts.
Signal Analysis Beyond the Instrument
Alongside the new probe, Siglent also introduced its SigVSA vector signal analysis software for Windows and Linux. The company offers this software as either a desktop application or an embedded version that runs directly on supported Siglent oscilloscopes and spectrum analyzers, including the SDS7000A with the RFA option. SigVSA supports everything from basic modulation schemes like BPSK to more demanding wireless standards, including LTE, 5G NR, Wi-Fi, Bluetooth, and UWB, as well as signals up to 4096QAM. That gives engineers a single platform for analyzing a wide range of communication signals, rather than switching between multiple software packages.
SigVSA supports analysis of wireless standards including Wi-Fi, LTE, 5G NR, Bluetooth, and UWB.
The software also includes features for both lab and production work, including offline waveform analysis, remote instrument control, synchronized acquisition from up to 32 instruments, multi-window displays, and customizable workspaces. Because the desktop and embedded versions use the same interface and measurement engine, engineers can move between PC-based analysis and instrument-based testing without learning a different workflow.
Siglent says support for additional protocols, including NB-IoT, GSM, WCDMA, DVB-S2/S2X, and FMCW, is planned for future updates.
With the SAP8000D active differential probe and SigVSA software, Siglent is adding new tools for both signal measurement and analysis. The combination of 8-GHz bandwidth, 300-fF input capacitance, broad wireless protocol support, and flexible desktop and embedded software gives engineers additional options for debugging high-speed digital interfaces and analyzing modern RF communication signals.
All images used courtesy of Siglent.
