UCLA and Broadcom Team Up to Craft Wafer-Scale Unidirectional Imager
A new multilayer diffractive optical processor blocks images in one direction while passing them in the other.
News August 18, 2025 by Luke James
Researchers at UCLA and Broadcom have developed a visible-spectrum imager that can do something conventional optics cannot: enforce one-way imaging. Leveraging a novel nano-fabrication process and deep learning-based design, the new platform marks the first wafer-scale, multilayer diffractive optical processor for broadband unidirectional imaging, potentially paving the way for practical applications in secure imaging, compact multispectral cameras, and computational optics.
Diagram of the wafer-scale nano-fabrication
The UCLA and Broadcom researchers have developed a broadband, unidirectional imager operating in the visible spectrum..
What makes the breakthrough notable isn’t just the physics behind it, but the scale. Built using lithographic techniques compatible with standard semiconductor manufacturing, the imager moves the concept of one-way vision out of lab-scale demonstrations and into the realm of mass production.
The device, fabricated on high-purity fused silica for high transparency and thermal stability, achieves strong directional selectivity using nano-patterned diffractive layers stacked to modulate light across multiple planes. The result is a system that enables image transmission from one side while distorting or suppressing it from the opposite side, something unattainable with conventional optics alone.
A New Take on Imaging Control
Historically, the promise of diffractive optics in imaging and computing has been hamstrung by fabrication constraints. Most existing implementations operate in the infrared spectrum or rely on single-layer 2D metasurfaces, limiting performance and design flexibility.
The UCLA-Broadcom team bypassed these limitations by developing a high-resolution, multilayer fabrication strategy that yields dense, polarization-insensitive nanoscale features, which are fine enough for visible light wavelengths. Just as crucially, these features were not handcrafted but optimized through machine learning, using a deep neural network to perform inverse design across multiple stacked optical layers.
In a standard optical system, light travels symmetrically through the lenses, meaning that reversing the direction yields essentially the same image path. But this new imager breaks that symmetry. In testing, it demonstrated clear image transmission from a designated input field of view to an output, while significantly degrading or scrambling images traveling in the reverse direction. That opens the door to novel optical privacy techniques, where cameras, sensors, or even AR/VR displays can “see out” while preventing outside observation.
Illustration of broadband unidirectional visible imagers
Illustration of broadband unidirectional visible imagers using wafer-scale fabrication of multi-layer diffractive optical processors.
Manufacturing at Scale
The success of this approach hinges as much on process engineering as optical design. By adopting lithographic techniques aligned with semiconductor workflows, the team achieved a level of repeatability and scalability rarely seen in experimental optics. These techniques include alignment-tolerant layer stacking and high-aspect-ratio etching on substrates with minimal optical loss. In addition to expanding the design space, the use of commercially viable materials and processes could enable wafer-scale integration with existing optoelectronic platforms such as CMOS image sensors or AR microdisplays.
The multilayer design also helps mitigate common tradeoffs in diffractive optics, specifically, the narrow spectral bandwidth and high polarization sensitivity that limit earlier metasurface designs. In contrast, this system operates across a broad swath of the visible spectrum while maintaining imaging quality regardless of input light polarization. Such robustness is essential for real-world applications ranging from mobile devices to autonomous sensing systems.
What Comes Next?
Ultimately, this research could open the door to a new class of optical processors that can perform computational imaging tasks passively, without digital post-processing. Potential applications include compact hyperspectral imagers, directional optical isolators, and secure sensing platforms for environments where conventional imaging might pose a privacy or security risk. Because the system can be batch-fabricated on standard wafers, it also presents an attractive option for industrial scaling.
By bridging deep learning-based optical design with semiconductor fabrication, the UCLA and Broadcom team has effectively turned a physics novelty into a viable component. If commercialized, it could provide a new tool for engineers looking to reimagine how devices see.
All images (modified) used courtesy of the Ozcan Lab at UCLA.
