xMEMS Launches ‘World’s Smallest Active Micro Fan’ for Smart Glasses
The XMC-1200 is a 1-mm-thin piezoMEMS cooling chip designed to keep heat away from temple arms.
xMEMS Labs recently introduced the XMC-1200, a solid-state micro fan that the company calls the world's smallest active cooling device. The 46 mm2, 1-mm-thin chip is designed to fit inside the temple arms of AR, XR, and AI-powered smart glasses, where it provides targeted airflow to light engines, processors, and camera systems.
The device features a 70-mW typical power consumption in a 46-mm2 footprint.
No Rotating Parts
xMEMS built the XMC-1200 on the piezoMEMS platform the company originally developed for its solid-state MEMS speakers. Thin-film piezoelectric actuators deposited on silicon flex at ultrasonic frequencies when driven, and the resulting membrane motion produces rapid pressure pulses that merge into a continuous stream of directed airflow. Because every moving element is a silicon membrane rather than a motor, bearing, or blade, the chip operates silently and without vibration. It also inherits the part-to-part uniformity and reliability of semiconductor manufacturing. The device carries an IP68 rating against dust and water ingress.
xMEMS says the XMC-1200 brings targeted active cooling directly at the source.
xMEMS classifies the XMC-1200 as an active convection chip. Where passive approaches, such as graphite spreaders and vapor chambers, can only relocate heat within a chassis, the XMC-1200 generates airflow directly at the component being cooled. Paired with the company's Astra2 drive ASIC, the system consumes 70 mW of typical power while moving up to 10 cc/s of air, which xMEMS says yields up to a 10°C temperature reduction at a 1-W thermal load.
The new part joins the XMC-2400, a larger µCooling chip measuring 9.26 mm x 7.6 mm x 1.08 mm that delivers up to 39 cc/s of airflow against up to 1,000 Pa of back pressure. The XMC-2400, aimed at higher-power glasses processors, is in mass production today and is supporting xMEMS' first glasses design wins.
Breaking the Thermal Wall
Thermal management has become a defining constraint for smart glasses. Light engines, camera systems, and the SoCs running on-device AI, translation, and high-resolution video keep growing more power dense, while the glasses themselves must stay thin, lightweight, quiet, and cool enough for all-day wear. Designers respond by limiting display brightness, throttling processors after short bursts, and capping video recording time to prevent overheating.
As devices get hotter, rotating fans simply won’t be able to fit inside the small profiles of smart glasses. xMEMS says the XMC-1200 is the first active cooling solution that’s small, thin, and efficient enough to work inside this class of electronics.
Why Active Cooling?
Beyond raw heat removal, xMEMS points to several system-level gains. Microdisplay LEDs and laser light sources drift in wavelength as they heat up, contributing to color bleed and white-point shifts. Holding them at lower temperatures supports more consistent color accuracy, contrast, and brightness.
Cooler processors sustain real-time AI, computer vision, and translation workloads without throttling, and can extend recording sessions that are currently cut short by thermal limits. The chip can also move heat away from the temple arm before it reaches the wearer's skin—an important factor, since accumulated heat remains a barrier to mainstream adoption.
Beyond eyewear, the company's µCooling portfolio targets other thermally constrained hardware, including SSDs, smartphones, and AR/XR systems, where the same solid-state airflow can substitute for fans that would otherwise be too large, too loud, or too failure-prone.
xMEMS is distributing XMC-1200 engineering samples to lead OEMs now, with volume production following in Q4 2027.
