Introduction to Near-Field Probes and Their Use in EMC Troubleshooting
Learn about the working principles of near-field probes and their applications in troubleshooting EMI issues.
Before they can be released to market, electronic products must meet legal standards for electromagnetic compatibility (EMC). EMC refers to a system’s ability to operate correctly without interfering with other equipment or being affected by external disturbances. Since it’s impractical to test this for every potential use case, EMC standards include a set of rules and conditions for evaluating a product’s performance.
EMC testing falls into two primary categories:
- Emissions testing: Ensures that the energy emitted by the power lines, communication lines, and the system itself remains within acceptable limits. Equipment often fails emissions testing because some part of it generates excessive radiated energy.
- Immunity testing: Verifies that the equipment under test (EUT) maintains functionality even when subjected to external interference. The most common reason for failure is one or more of the EUT’s components being too sensitive to the applied electric or magnetic fields.
It’s important to tackle EMC compliance from the early stages of product development, while there’s still time to fix any issues that arise. Once the system has been designed and built, it becomes harder to make necessary modifications.
Unfortunately, when issues occur during a formal EMC testing campaign, it can be difficult or even impossible to know the exact position of the problem. For example, say that we’re testing a system in an EMC chamber. Every EMC issue has three parts:
- Source: The component or structure generating the excessive emissions.
- Victim: The component(s) affected by the emissions.
- Coupling path: The route from the source to the victim.
An EMC chamber measures emissions in the far field, so the victim here would be the measuring antenna and the path would be the free air inside the chamber. However, we still don’t know the source of the emissions.
Alternatively, say that the screen of a computer starts blinking during a radiated immunity test. The effect of the problem is visible on the screen, but the source of the problem could be screen cables with faulty shielding, the main processor’s sensitivity to the testing frequencies, or something else entirely.
Identifying the cause of electromagnetic interference (EMI) often requires special tools. In fact, just one tool can potentially eliminate hours of troubleshooting—if that tool is a near-field probe. We can use near-field probes to identify both the source and the victim during EMC testing. As we’ll discuss later on in the article, they can also be used to verify the effectiveness of EMI shielding.
What are Near-Field Probes?
Near-field probes (Figure 1) are diagnostic tools for measuring electromagnetic fields in close proximity to their source. They’re made to be sensitive to either electric (E) fields or magnetic (H) fields. By contrast, far-field measurements can’t separate the E-field from the H-field, making it hard to pinpoint where interference is coming from.
Figure 1. A near-field probes kit. Image used courtesy of Tekbox
The physical workings of near-field probes are based on Maxwell’s equations. An E-field probe generates a measurable voltage when placed into a time-varying electric field. Similarly, an H-field probe generates a measurable current in the presence of a time-varying magnetic field.
Near-field probes, whether E-field or H-field, are usually used with a spectrum analyzer to observe the frequency distribution. If you want to observe the time variation, however, it’s also possible to use near-field probes with an oscilloscope.
Why Use Near-Field Probes in EMC Testing?
As we mentioned above, near-field probes can help us do the following during EMC troubleshooting:
- Identify emissions sources.
- Find sensitive components.
- Verify the effectiveness of shielding.
Identifying the Sources of Emissions
Let’s return for a moment to our first example, where we were testing a system in an EMC chamber and encountered excessive emissions. To troubleshoot, we need to know which component or structure is the source of the problem. How can near-field probes help us find it?
In the near field, we’ll have a dominant electric or magnetic field. We’ll therefore need both E-field and H-field probes to find the emissions source. To measure the emission levels, we place the probes close to the circuit. Knowing the frequency or frequencies where there are high levels of emissions, we can measure the magnetic or electric field around the EUT.
Finding Sensitive Components
In immunity tests, we apply strong electric or magnetic fields and observe whether the system keeps working as intended. When a system fails a test, it’s because a component or group of components is sensitive to the applied field and its frequency. Assuming we know the frequency bands that might disturb the EUT, we can connect a signal generator to a probe and generate a field that replicates the behavior observed in the EMC laboratory.
Verifying Shielding Effectiveness
EMI shielding serves to absorb or reflect electromagnetic energy. Figure 2 shows an example of EMC tape, a form of EMI shielding.
Figure 2. EMC tape used to shield electronic devices. Image used courtesy of Holland Shielding
When designing a shield, there are two main parameters to consider:
- Frequency range.
- Attenuation.
To measure the shield’s effectiveness, we connect one near-field probe to a signal generator and a second near-field probe to a spectrum analyzer. Kenneth Wyatt’s article “Measuring Shielding Effectiveness With Two Near-Field Probes” describes this process in detail. To avoid false measurements, be sure to consider the frequency limitations of the probes.
Effective Use of Near-Field Probes
Now that we have a clear picture of why near-field probes are useful in EMC troubleshooting, let’s briefly review some tips for getting the most out of your probes. The most common setup is a probe connected to a spectrum analyzer through a coaxial cable. To reduce high-frequency noise coupling directly into the cable, you may need to add a ferrite to the coax.
The probe size will determine its sensitivity. Big probes can capture high levels, but have low spatial resolution. Start with big probes, then use smaller ones once you identify the area producing emissions. Be systematic and follow an iterative approach.
Having accessible tools to troubleshoot EMC issues is critical to keeping risks under control. Near-field probes are easy-to-use tools that can be used from the first prototype up through the whole system’s certification in an accredited laboratory. As we’ve now seen, they can serve to locate problematic components or measure the effectiveness of a shielding structure. By doing so, near-field probes help hardware designers and EMC testers reduce time-to-market at an affordable price.
